Two clutches mounted on the crankshaft. The outside clutch is the low speed. When the engine reaches a certain RPM, the second clutch engages and changes the gear ratio of the trans. Basically like a two speed automatic. A control in the front allows you to shift the trans to forward, reverse , or neutral .
