Page 2 of 7 FirstFirst 1234 ... LastLast
Results 11 to 20 of 64
Thread: Will HAARP-like research project affect HF propagation?
    Jodie Foster played James Bond? Who Gnu?
    I wonder how Mr. French and Buffy are doing?
    "Will HAARP-like research project affect HF propagation?"
    That's the whole idea behind government research into future weapons technology. Wipe out HF radio battlefield communications, generate disaster weather conditions, and mind control over the target area. If you have any doubts ask Jesse Ventura, he knows. Oh, don't expect your tin foil hat to protect you from HF mind probes, they only can reflect microwaves.
    Cause of earthquakes?
    Also, readings from the HAARP Induction Magnetometer, which visualizes the frequency spectrum of signals detected in the earth's geomagnetic field, show that a steady, ultra-low frequency (ULF) of roughly 2.5 Hz was being broadcast days before the earthquake. The 2.5 Hz ULF happens to be the exact same frequency as the natural resonance produced by an earthquake -- and since there were no constant earthquakes occurring on the days before the quake as the HAARP Induction Magnetometer appeared to indicate, the logical conclusion is that the signal was being broadcast to induce the quake (http://presscore.ca/2011/?p=1624).
    Some would argue that HAARP is not capable of producing such frequencies, especially at the power levels that would be required to induce a massive earthquake like the 9.0+ that occurred in Japan. But testimony by various governments says otherwise.
    On April 28, 1997, then US Secretary of Defense William S. Cohen gave an important keynote address at the Conference on Terrorism, Weapons of Mass Destruction, and US Strategy at the University of Georgia in Athens. When asked a question about terrorism, Cohen had this to say as part of his response about the type of technology that existed, even back then:
    "Others are engaging even in an eco-type terrorism whereby they can alter the climate, set off earthquakes, volcanoes remotely through the use of electromagnetic waves" (http://www.defense.gov/transcripts/transcrip...).
    This admission counters the claims made by some that no such technology exists, and that it is impossible to create seismic activity using directed energy. Clearly the technology has been around for a while, and the notion of it being used as a weapon is anything but a baseless conspiracy theory.
    Then, there is the EU report on the environment, security and foreign policy, that was released on January 14, 1999 (http://www.europarl.europa.eu/sides/getDoc.d...). This report outlines various types of weapon threats, including a section entitled, "HAARP - a weapons system which disrupts the climate."
    The paper explains that HAARP is "run jointly by the US Air Force and Navy," and that one of its purposes is "to heat up portions of ionosphere with powerful radio beams." It also states the following important details:
    Learn more: http://www.naturalnews.com/032670_Fu...#ixzz300VSx4el
    http://www.naturalnews.com/032670_Fukushima_HAARP.html
    Quote Originally Posted by W9JEF View Post
    And, the tightening if tin foil begins...
    More evidence...
    The chart below is a running 36 hour plot of the readings taken from the fluxgate magnetometer, built by the University of Alaska, Geophysical Institute, operating at the HAARP ionospheric observatory in Gakona, Alaska. The three traces represent mutually orthogonal components of the earth’s magnetic field as follows:
    • The “H” component (black trace) is positive magnetic northward
    • The “D” component (red trace) is positive eastward
    • The “Z” component (blue trace) is positive downward
    Geomagnetic storminess is usually indicated in oscillatory variations in the earth’s magnetic field. Additional detail concerning the nature and severity of the ionospheric disturbance can be found through analysis of the three components of the field.
    This is proof they fired up their equipment during this time period leading to the day of Japan Earthquake. After all this is their Fluxgate magnetometer used at their facilities in Alaska. So their you go my friend man is destroying this world with their doomsday toys. Below is a link so you can track when they fire it up next. Just click on update and watch them destroy more life’s before your eyes.
    http://137.229.36.30/cgi-bin/magnetometer/gak-mag.cgi
    http://www.federaljack.com/evidence-...n-on-03112011/
    You should know that my ask Jesse "The Body of a Jackass" comments were purely intentional tongue in cheek... MIND CONTROL? Really? The rest is based in fact:
    "Clearly the technology has been around for a while, and the notion of it being used as a weapon is anything but a baseless conspiracy theory."
    Experiments by Nikola Tesla continue new and improved, you really should read up on this amazing scientist who was way ahead of his time. His experiment with an "earthquake machine" using resonance likely is one, it's not too hard to believe that tweaking the Earth's magnetic field at the planet's natural resonance can produce an earthquake but the trick is targeting a specific area. Is it too far fetched that Fukushima was collateral damage in such an experiment? OK, I'll tell you again, I may be crazy but I'm not stupid, but when it comes to government stupidity anything is possible and you KNOW that.
    Forget about The Twilight Zone, this is just one of the things the government is doing taking us to The Outer Limits... they are...
    If I hear any more ignorant fearmongering, I'm gonna go out and club a baby HAARP seal.
    ....... or to put the "tin foil hat gang" firmly in their place while another mass global conspiracy races around everyone.... we can all sing: "HAARP the herald angels sing".....could be a popular tune come Christmas time!
    I just find it amazing how hams of all people can be sucked in by the conspiracy theories surrounding the HAARP project... If hams think HAARP can change weather patterns, I wonder what they think we do to the weather on contest weekends.
