Page 1 of 4 123 ... LastLast
Results 1 to 10 of 39
Thread: New piece of CB gear - purists are gonna cry
    Managed to find a couple of Stoner Pro-40s out in Never-never-land. For those unfamiliar with the rig, it's an SSB-only 11M set with an audio notch filter ("whistlestop") and passive mixer front end - as the Drake 7-lines employed. They're pretty popular with the die-hard collector and command big money.
    One of these is likely a parts/project rig - I think the synthesizer microcontroller is bad. Thus, I'm going to design a new one for it.
    Here's where the purists will cry:
    That radio just begs for additional features - bring the Mic Gain out to a front panel control, do something with selectable AGC time constants and selectable IF RX filters. Fortunately, they're 10.7MHz and I can find a variety of bandwidths...including a roll-your-own "variable" design.
    If I have to create a synthesizer computer from scratch it'll offer dual logical channel selectors and a way to use them in split mode for TX/RX. Extended frequency ranges, albeit RX-only with a transmitter lockout. A "busy/free" scan function. Improved power supplies. All this without changing anything to do with the TX signal chain - from oscillators through PA. The front panel will remain untouched except for the addition of some concentric knobs - the ones I have in mind look better than the OEMs.
    Currently on the hunt for accessories for the radio - SPK-40, OSC-40, SOC-40 and anything else which goes with it.
    Stick that baby on 10M and have a ball with Ham purists. What's your radio? A Stoner PRO-40. A WHAT?? ;)
    She is a beauty. A bit of overkill on 11M though. I'd think of a crystal filter myself. Maybe a rock with some low-end DSP to deal with static crashes.
    Conch Master W2NAP's Avatar
    Mar 2008
    W2NAP
    no excuses on da bowl.
    Mystical Drummer NY4Q's Avatar
    Aug 2012
    Dahlonega, GA
    For some reason, that CB rig reminded me of some lyrics that were posted on USENET back in the 90s. I found them funny. So I present them here for you...
    Code:
    Sang to the tune of The Highwayman                       Written By M.F. Luder
                           I was a codeless "ham"
                           Along the coach roads i did ride
                           With dual band HT by my side
                           Many a young maid ran from my tirades,
                           Many a repeater contact I had made
                           The League grandfathered me in the spring of o-one
                           But still I want more, my whinings never done
                           I was a sailor,
                           I was born upon the tide
                           On 14325 did i abide
                           I sailed a schooner 'round the horn to mexico
                           I went aloft to furl the Outbacker in a blow
                           And when the mast broke off,
                           They said that my signal was killed
                           But i am living still
                           I was a damn CBer
                           Across the South deep and wide
                           Where shooting skip was my only pride
                           A place called New Orleans on the Mississippi low
                           I bought an amp that would let me bellow
                           They DF'd me by listening for the crackling sound
                           But i am still around
                           I'll always be around and around and around...
                           I'll talk on 10 meters
                           'Cross the Continental divide
                           And when i reach the other side,
                           I'll find a place to rest my Budweiser in a can
                           Perhaps i may become a highwayman again
                           Or i may simply be a single jamming pain
                           But i will remain
                           And i'll shoot skip again and again and again...
    أبدا ستعمل تعطيك ما يصل
    Aug 2012
    Dahlonega, GA
    That passive mixed can handle da bowl...
    Quote Originally Posted by N4BBQ View Post
    That radio is SSB only. Da Bowl been flushed by its designer, none other than W6TNS.
    Aug 2012
    Dahlonega, GA
    Oh I know, but with that mixer, the mobile super bowl could drive right by your QTH while in a "radio race" and you'd still be able to conversate, methinks.
    What's it got DBDR?
    What's it got DBDR?
    HP hot-carrier diodes in a quad. Not sure of the device numbers. I'm going to do some BDR and close-in IMD testing, and may end up experimenting with a matched quad of 1N5711s if the OEM parts aren't quite up to the job.
    No 'bowlers in my immediate area so I don't have that problem to worry about.
    Last edited by N8YX; 02-09-2014 at 06:57 AM. Reason: Extra characters at bottom removed...)
    Aug 2012
    Dahlonega, GA
    Yeah, that's gonna be a fun project. That front end sounds bullet proof.
    It's so darn Ten Tec looking... ;)
