Page 3 of 3 FirstFirst 123
Results 21 to 28 of 28
Thread: Which Coax do you recommend?
    The Armpit Of, TX.
    I ended up buying 30' of LMR400 at the supply store today.
    Oh, almost forgot one of the MOST important facts about CATV coax, aluminium shield so you can't solder to it. That's why installers use crimp connectors, usually an F and like RG6 quad shield and relayed lines ordinary F connectors don't fit. Still it's a cheap and dirty way to go, connectors, adapters and don't forget the stripper and crimp tool don't cost as much as"standard" cable and connectors for VHF/UHF work. Remember CATV cable has low loss up there because all signals are above 50MHz and up into the low GHz range. Unless you're running a kilowatt for EME you may as well clean off the couse while you're at it.
    Yeah, hard line is best, etc., etc., which is why only well funded clubs and hams use it. If you own a TV station you can afford hard line.
    When we used 4 inch hard line at the radio station, I found that plumbing skills were very useful.
    Just don't confuse hard line with waste line!
    Actually, they can both be full of shit.
    Island Dog Bubba's Avatar
    May 2013
    U-Tapao
    What do you do with 6 inch hardline ??
    The Armpit Of, TX.
    Quote Originally Posted by Bubba View Post
    Thats what she said...
    Quote Originally Posted by K9CCH View Post
    Good job. Would have been my choice too. Nice bang for the buck factor.
    Master Navigator
    Sep 2012
    Yes, you made a good choice. For a 30' run on 2 meters, I'm not that picky, but LMR400 is a good thing to use.
