Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Wire antenna musings.
    Good.
    ON4UN's book led me to make several 160 meter verticals resulting in the last one 77 feet high and 77 feet top section in wire running down to 45 feet above ground.
    And a as good as possible ground radial net i could get away with, and the autotuner MFJ 998 at the feedpoint to make it a multiband L.
    I can tune it from 160 - 10 without problems, i kept the L longer as a 1/4 wave on 160 to prevent the L being a 1/2 wave and high impedance on 80.
    Up to 20 meters good for DX, low angle of radiation and above 20 the pattern rally starts to break up, it will work, but a seperate vertical 35 feet high on the roof for 17-10 works better there.
    My OCF ( Fritzel FD-4 with AMA 83 balun for 1500 watts is altered with a coil of 190 Microhenry and 9 meters of wire so it is resonant on 160 as well and works bar a few Warc bands up to and 10 meters.
    I made a recieve active loop of aluminium strip 14 feet long in a loop with a long tailed pair BFW 16 A transistors in class A for reception 30 Khz to 50 MHz.
    So on each band i can chose for reception the loop a vertical or horizontal polarised antenna and pick the one that gives the best results.
    I live on the edge of my city, and have S6 noise on the vertical on 160 the loop is having a better signal to signal/noise reception.
    I build and tried EWE antenna's K9AY loops, amplifiers for them, and all mostly made from scrap material.
    Building your own stuff, even ladderline, is cheap, gives more satisfaction, and you have no costs changing the stuff.
    I'm always looking for copper wire to add to the collection, bought a bunch of roseclips used by the growers of roses that keep a wire 3 inches apart costing peanuts, to make my own ladderline, or make them yourself ( try plastics in the microwave with a glass of water next to it to see if it is not conducting R.F., if it gets hot don't use it.)
    My plot of land including the house is just 100 x 25 feet large, see piccies at qrz looking me up there.
    My radials are all over the place some 40 feet long a few 100 yards long in my plot, the neigbours etc.
    I can run 1000 watts here without having neighbours here coming to my door with pitchforks demanding me to stop ;)
    I connected the house ground to my station as well the elaborate groundstake system of 17 x 10 feet long copper pipes.
    Even the stainless kitchen sink is connected to that... as well waterpipes, gas pipes ( all copper here) and zinc gutters.
    Near the foot of the vertical use chicken wire to cover as much and dense the ground, here the largest currents run to the feedpoint, connect the ground wires to that and run them to the feedpoint, use silver solder to connect them not the normal solder, it wlll corrode into dust in 1 or 2 years.
    Cadwelding is the best option, clamping on a ground plate from stainless steel works too.
    Check your system every year, using my MFJ 269 antenna analyser i noted down the data and check each year if nothing changed signaling a problem.
    Just a few grabs of my experiences here for the last 36 year hamming...
    And have fun ;)
    Quote Originally Posted by w0aew View Post
    Use the doublet and don't worry about 80m DX. That's what the other bands are for.
    :rofl:
    QSO: 3500 PH 2010-03-06 0217 KS3D 59 DE VP5H
    QSO: 3500 PH 2010-03-06 0221 KS3D 59 DE CT3DL
    QSO: 3500 PH 2010-03-06 0223 KS3D 59 DE V26M
    QSO: 3500 PH 2010-03-06 0236 KS3D 59 DE 6Y9V
    QSO: 3500 PH 2010-03-06 0245 KS3D 59 DE EA3WD
    QSO: 3500 PH 2010-03-06 0248 KS3D 59 DE 9A1A
    QSO: 3500 PH 2010-03-06 0251 KS3D 59 DE J7Y
    QSO: 3500 PH 2010-03-06 0257 KS3D 59 DE DF7ZS
    QSO: 3500 PH 2010-03-06 0416 KS3D 59 DE C6AMM
    QSO: 3500 PH 2010-03-06 0416 KS3D 59 DE G4PWA
    QSO: 3500 PH 2010-03-06 0418 KS3D 59 DE TO5A
    QSO: 3500 PH 2010-03-06 0427 KS3D 59 DE DR1A
    QSO: 3500 PH 2010-03-06 0428 KS3D 59 DE P40A
    QSO: 3500 PH 2010-03-06 0431 KS3D 59 DE C6AWL
    QSO: 3500 PH 2010-03-06 0436 KS3D 59 DE 8P6EX
    QSO: 3500 PH 2010-03-06 0437 KS3D 59 DE S53O
    QSO: 3500 PH 2010-03-06 0446 KS3D 59 DE YV5MSG
    80m PH 07/15/12 0319 IO4HQ 59 08 59 ARI
    80m PH 07/15/12 0321 E70ARA 59 08 59 ARABH
    80m PH 07/15/12 0322 DA0HQ 59 08 59 DARC
    80m PH 07/15/12 0324 CR3T 59 08 59 36
    80m PH 07/15/12 0328 LX75HQ 59 08 59 RL
    80m PH 07/15/12 0329 OL2HQ 59 08 59 CRC
    80m PH 07/15/12 0331 HB9HQ 59 08 59 USKA
    80m PH 07/15/12 0335 DH8BQA 59 08 59 28
    80m PH 07/15/12 0337 HB9OK 59 08 59 28
    80m PH 07/15/12 0343 S50HQ 59 08 59 ZRS
    80m PH 07/15/12 0345 TM0HQ 59 08 59 REF
    80m PH 07/15/12 0402 GO2HQ 59 08 59 RSGB
    80m PH 07/15/12 0404 EF1HQ 59 08 59 URE
    80m PH 03/02/13 0021 OK7K 59 DE 59 OK!
    80m PH 03/02/13 0023 9A7A 59 DE 59 9A
    80m PH 03/02/13 0026 HF8J 59 DE 59 SP
    80m PH 03/02/13 0027 C6ANM 59 DE 59 C6
    80m PH 03/02/13 0030 E7DX 59 DE 59 E7
    80m PH 03/02/13 0030 9A1P 59 DE 59 9A
    80m PH 03/02/13 0031 OK2RZ 59 DE 59 OK!
    80m PH 03/02/13 0032 HG7T 59 DE 59 HA
    80m PH 03/02/13 0034 G4PKP 59 DE 59 G
    80m PH 03/02/13 0035 S58FA 59 DE 59 S5
    80m PH 03/02/13 0037 II9P 59 DE 59 IT9
    80m PH 03/02/13 0038 YT9A 59 DE 59 YU
    80m PH 03/02/13 0039 CT2ITR 59 DE 59 CT!
    80m PH 03/02/13 0040 G5W 59 DE 59 G
    80m PH 03/02/13 0041 KP4KE 59 DE 59 KP4
    80m PH 03/02/13 0042 9A1A 59 DE 59 9A
    80m PH 03/02/13 0043 9A7DM 59 DE 59 9A
    80m PH 03/02/13 0044 VP9I 59 DE 59 VP9
    80m PH 03/02/13 0053 OM2KI 59 DE 59 OM
    80m PH 03/02/13 0441 CR2X 59 DE 59 CU
    80m PH 03/02/13 0443 OS8A 59 DE 59 ON!
    80m PH 03/02/13 0450 3V8BB 59 DE 59 3V
    80m PH 03/02/13 0451 CS2C 59 DE 59 CT!
    80m PH 03/02/13 0455 EA7EU 59 DE 59 EA
    80m PH 03/02/13 0458 GM3PPG 59 DE 59 GM
    80m PH 03/02/13 0642 PJ2T 59 DE 59 PJ2
    80m PH 03/02/13 0648 M8C 59 DE 59 G
    80m PH 03/02/13 0650 EI7M 59 DE 59 EI
    80m PH 03/02/13 0651 8P5A 59 DE 59 8P
    80m PH 03/02/13 0654 LX7I 59 DE 59 LX
    80m PH 03/02/13 0658 KP2M 59 DE 59 KP2
    80m PH 03/02/13 0659 J88DR 59 DE 59 J8
    80m PH 03/02/13 0702 HI3TEJ 59 DE 59 HI!
    80m PH 03/02/13 0704 CM5FZ 59 DE 59 CM
    80m PH 03/30/13 0239 9A8M 19 59 59 310 * 9A8
    80m PH 03/30/13 0242 TM7F 20 59 59 242 * TM7
    80m PH 03/30/13 0248 DR1D 21 59 59 282 * DR1
    80m PH 03/30/13 0252 D4C 23 59 59 259
    80m PH 03/30/13 0255 CF3A 25 59 59 375 * CF3
    80m PH 03/30/13 0256 II9P 26 59 59 312 * II9
    80m PH 03/30/13 0300 EF5Y 27 59 59 281 * EF5
    80m PH 03/30/13 0305 YU0K 28 59 59 156 * YU0
    80m PH 03/30/13 0307 TM6M 29 59 59 307 * TM6
    80m PH 03/30/13 0310 CN2R 30 59 59 480 * CN2
    80m PH 03/31/13 0233 HA8RM 150 59 59 10 * HA8
    80m PH 03/31/13 0239 DR1A 153 59 59 979
    All done with 100 watts and a 134 foot doublet at 60 feet. Please note that you will not find one CW contact in that entire list, since I don't do that beeping crap.
    If the doublet is up at least 60 feet, there is still usable energy (broadside to the wire) down to 30 degrees TOA (assuming 3db down from max). If you only want to suffer a 2db loss, then you're at 35 degrees TOA.
    Now things may be different in CO, but Jim's on the East Coast. So am I. His results should be similar to mine.
    If I am designing antennas for DX, I am looking in the 10 degree TOA region to make my comparisons on the NEC analysis. I would never discourage someone from putting up just anything for an antenna, but if you can put up something with a better signal at a 10 degrees TOA, I would do that before settling for something that is many dB down at that TOA.
    :rofl:
    Ebil contesters.
    Oct 2011
    Hillsborough, NC
    Look at that, all 59 reports
    Jim
    Quote Originally Posted by KG4NEL View Post
    Ebil contesters.
    Yes, yes I am. :muhahaha:
    I wasn't aware there was anything else.
    November Sweepstakes. Not a signal report to be had.
    From http://www.arrl.org/sweepstakes :
    4. Contest Exchange: The required exchange consists of:
    4.1. A consecutive serial number;
    4.2. Precedence;
    4.2.1. “Q” for Single Op QRP (5 Watts output or less);
    4.2.2. “A” for Single Op Low Power (up to 150 W output);
    4.2.3. “B” for Single Op High Power (greater than 150 W output);
    4.2.4. “U” for Single Op Unlimited Single-Op Unlimited High Power and Single-Op Unlimited Low Power both send "U")
    4.2.5. “M” for Multi-Op (Multiop High Power and Multiop Low Power both send "M")
    4.2.6. “S” for School Club;
    4.3 Your Callsign;
    4.4. Check
    4.4.1. The last 2 digits of the year of first license for either the operator or the station.
    4.4.2. An entry must send the same Check throughout the entire contest.
    4.5. ARRL/RAC Section
    4.6 Exchange Example: NU1AW would respond to W1AW’s call by sending: W1AW 123 B NU1AW 71 CT, which indicates QSO number 123, B for Single Op High Power, NU1AW, first licensed in 1971, and in the Connecticut section.
