Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 39
Thread: 10 meter antenna's
    SK Member 8/11/2015
    Feb 2012
    N.E Ala
    I'm on a inverted v dipole now but have been thinking of going vertical.That gap titon looks complicated.the A 99 seems to be pretty popular.I'll have to look up the imax.I'm also working on a moxon with pvc pipe but in an H pattern.Thanks for all the replys so for,anyothers?
    Quote Originally Posted by kk4fpx View Post
    If you can find one, a Radio Shack 3-el CB yagi could be cut down and used on 10...easily turned with just a TV antenna rotator. A set of ground mounted, phased verticals would also work if your residence is fairly high in elevation.
    Wiscowsin
    Homebrew Moxon beam.
    It's up on a mast now, of course.
    Neat design, I might have to try one of those myself. I've done 6M moxons from some scrap 3/4 angle aluminum left over from a work project.
    I took some supplies to Field Day one year and built one from scratch on the tailgate of my truck with some of the newer hams. I replaced it a while back with a 3 element Cushcraft but I'm not convinced that the store bought antenna has been any better than my home built antenna.
    Quote Originally Posted by KC9ECI View Post
    Thanks. I ended up cutting the Y arms down by two inches each after I took that picture. They were the correct length at the time but the antenna resonated down around 27 MHz and by the time I shortened things up enough to get it to resonate outside the CB bands, the wire would no longer fit around the frame.
    If I had it to do over again, I'd use a smaller diameter pipe as well. I used 1-1/2" Schedule 40 PVC thinking it would make it rigid enough that it wouldn't require any extra bracing to keep the boom from sagging. It sagged anyway so it turned out to be a few wasted bucks, as well as some unnecessary weight. It is hell for stout, though.
    Nice—I think I'll try building one for six this summer. I could easily stack it on top of the 10m antenna.
    I've become a fan of Moxons after Gordon, AE6QW, and I built a 20m Moxon out of 1/2" Type M copper for Field Day last year. The thing looked like the aftermath of a boiler explosion but, damn, it worked great.
    Wiscowsin
    These are the plans I followed for the 6M: http://www.n2mh.net/moxon.htm
    I've wanted to try a 20M moxon for a while. I'll get around to it eventually. I think I have more fun screwing around with antenna projects than I do actually operating.
    SK Member 8/11/2015
    Feb 2012
    N.E Ala
    After tonights pile ups over australia I think I'll forget the vertical and finish my moxon.
    I'm just using an inverted V wire dipole cut for 10 meters and it's working great! ..... been working gray line south pacific VK's ZL's etc. without too much problem but it does tell that this sunspot cycle is definately a more challenging one to work with!
    Since we're down here in the extreme southwestern corner of the U.S., the wide main lobe made a Moxon a good choice. With the proper orientation, we could cover almost the entire lower 48 states without a rotor.
    I'm not good enough with electronics to do much in the way of serious home brew but I can build an antenna and since the Moxon is the only antenna I have at the moment that exhibits any actual gain, I'd have to say the same thing. That might change as I improve my antenna farm.
    Mar 2008
    San Vicente, Alicante, Spain
    Solarcon Antron 99. Added a radial for 17/20. Some signals on 20m sound better, others don't. Just depends. With the tuner it tunes up fine. Several years ago I used it on 6m.
    Same here. Also I have a homebrew 10m beam. Though, I only work Dx by accident. =P
    SK Member 8/11/2015
    Feb 2012
    N.E Ala
    I think I'm going to take John's advice and get a CB or 10 meter 3 element beam.I'm going to wait until after our ham fest here in Fort Payne before I buy one.It's on the 9th if anyone here is close enough to make it.
