Results 1 to 10 of 16
Thread: power supply
    SK Member 8/11/2015
    Feb 2012
    N.E Ala
    power supply
    I bought a 3 amp power supply today,my transciever needs 7 amps.What would happen if I connected it in parallel to a battery?
    The same thing mine did, charge the battery. My first power supply was one of those puny supplies and a car battery, it worked.
    At three amps, I'd worry a bit about it overcharging the battery if left on for long periods of time. If you're only going to turn it on while you're using it, though, you should be okay.
    Do it, but add a charging regulator between the battery and supply.
    +1.
    Sunlight Energy Systems (WB8VGE) used to offer a nice one.
    SK Member 8/11/2015
    Feb 2012
    N.E Ala
    Thanks,I bought it for my son in law for temp use.He is taking his tech exam tuesday.
    Forum Addict KA9MOT's Avatar
    Apr 2010
    Macomb, IL
    +1.
    Or build your own!
    http://www.parc.org.za/attachments/p...ar Charger.PDF
    http://rysiny.ovh.org/elektronika/Sh...is_Greacen.pdf
    If nothing else, this one is a good read and can get some thought juices flowing.
    http://www.freemansgarage.com/wind.html
    And off topic, but I found it interesting:
    http://www.i4at.org/surv/tow02077.htm
    Steve KA9MOT
    Macomb, IL
    Orca Whisperer N2RJ's Avatar
    USA
    It could just charge the battery, fry the battery or fry the PSU.
    It depends on the size and type of battery. If it is a deeply discharged AGM battery for example it will fry the power supply for sure (or trip its overcurrent mechanism, or blow the fuse).
    Wiscowsin
    USA
    Quote Originally Posted by KC9ECI View Post
    Good find. That will work nicely with a 120w panel which makes it perfect for field day.
