I have an amplifier that was constructed by the real "Palomar Labs" back in the 70's, it is a Model #5300 with a low pass filter section on the output and, a band switch selecting the 80 through 10 meter low pass filters. It has a regulated B class bias voltage on the input transformer, the power switch now activates a relay to switch +12 volts to the amp and, the Antenna Switch relay failed and had to be replaced with a different model because the stock part is no longer attainable (and was too small for the output).
I also have an Input matching circuit board designed to match a 50 ohm transmitter to the cathode of a four sweep tube amplifier
So, i'm thinking that I can hook the original 50 impedance side to the input transformer and the output side to the MFJ 259 antenna analyzer and rework the caps and coils to work from 50 ohm radio input to transistor input matching impedance.
Does this sound like a feasible project?
BTW: also posted in Technical section of the swamp; I know i'm gonna get a bunch of Snarky-Chicken Band remarks but, I really thinking about doing this.
