Page 1 of 17 12311 ... LastLast
Results 1 to 10 of 167
Thread: EB104 amp project
    Tribal Elder mw0uzo's Avatar
    Dec 2010
    Cardiff, Wales
    EB104 amp project
    Been building an amp.. enjoy 1st stage of amp module construction :)
    Drilling up the copper
    And the transistors
    And components
    transistors ...
    Test setup:
    First 100W! (of 600w)
    Dec 2010
    Cardiff, Wales
    Brackets
    Wiring
    Cover
    and laying out the insides
    Dec 2010
    Cardiff, Wales
    Rest of the amp will consist of custom PIC controller with 20 x 4 display (same as beacon), LPFs, foward and reverse power detection and input attenuators.
    Nice work. I wish I had a machine/metal shop.
    How many pills is that?
    Dec 2010
    Cardiff, Wales
    Thanks, no machine shop here, a shed and a jigsaw to cut the steel bits, a really cheap pillar drill and a £10 tap/die set from ebay. Copper was ordered as a piece which just happened to fit perfectly.
    Dec 2010
    Cardiff, Wales
    How high do you want to get ;)
    Dec 2010
    Cardiff, Wales
    the mrf150s i have are fakes, unfortunately. But after flattening the unbelievably wonky mounting tabs, they seem to work by some stroke of sheer luck. for how long though....
    Looks nicely done there :) Sorry you got some bunk components. Hopefully, real components wont throw anything off for you there on the final construction.
    Dec 2010
    Cardiff, Wales
    Yeah annoying. Plan is to build all the monitoring and protection before ramping up the power. The MRF150s are 'remanufactured' (very poorly). I do not expect them to last long or work properly, but if I can get away with fakes, decent monitoring and careful abuse then that would be great
