Results 1 to 10 of 17
Thread: Amplifier Rework Project
    I have an amplifier that was constructed by the real "Palomar Labs" back in the 70's, it is a Model #5300 with a low pass filter section on the output and, a band switch selecting the 80 through 10 meter low pass filters. It has a regulated B class bias voltage on the input transformer, the power switch now activates a relay to switch +12 volts to the amp and, the Antenna Switch relay failed and had to be replaced with a different model because the stock part is no longer attainable (and was too small for the output).
    I also have an Input matching circuit board designed to match a 50 ohm transmitter to the cathode of a four sweep tube amplifier
    So, i'm thinking that I can hook the original 50 impedance side to the input transformer and the output side to the MFJ 259 antenna analyzer and rework the caps and coils to work from 50 ohm radio input to transistor input matching impedance.
    Does this sound like a feasible project?
    BTW: also posted in Technical section of the swamp; I know i'm gonna get a bunch of Snarky-Chicken Band remarks but, I really thinking about doing this.
    First thing to look at is biasing, and how the design regulates it. Thermal stability is important here.
    The 3055 / regulator is bolted to heat sink
    Do the transistors all have been selected for the same bias setting? Motorola has a color dot for that, even then I build my amps with a bias circuit for each transistor with heat tracking as well.
    Nope, both pair of input transformers share the same bias supply.
    I see, and no temperature control either per transistor, which can cause a thermal run away when one is not in the selected bias configuration.
    Each of my transistors had a thermally coupled diode over the transistors each with it's own regulated bias from a low impedance source.
    Might be overkill, but according the Motorola handbook Engineering Bulletins that was how they did it and I followed their design.
    Transistors were quite expensive then.... ;)
    The rest looks like the same AB Motorola design, wideband input and output coupling and transformers.
    Even used it ( adapted) for 2 meter with 2 x the MRF 247 transistors.
    That one didn't have much gain, 35 watts in for 160 out but that was satisfactory then.
    Running that in 2 x 12 element beams was a hoot ;)
    Look on the net for the schematic diagram of the HLA 300V amplifier from European make, there is a HAM version of it with band filtering etc reasonably clean too for 300 watt.
    RM Italy does make a HLA-300V, 450 watt amplifier that has full auto band switch low pass filtering, with power meter and remote keying. I have tested the amplifier and it passes FCC certification but has not been certificated as of yet. You can buy them for about $360.
    You do need a 50 to 60 amp power supply for it though...
    http://pa0fri.home.xs4all.nl/Lineair.../schematic.pdf
    Schematic diagram.
    http://pa0fri.home.xs4all.nl/Lineair.../hla300eng.htm
    Detailed description of that amplifier and test.
    Cor nailed it - per-device thermal feedback to regulate bias or you'll get one or two that "hog" the load as die temps increase.
    That bias circuit should be your first remediation point.
    https://forums.hamisland.net/showthr...04-amp-project
    Nice work here with a balderdash of info about such amp ;)
    I remember that thread, he documented his whole project but, there are a couple of major differences:
    1. He started with a bare board, that was new construction; my circumstance is repair / retuning
    2. His amp used control modules that are 40 years forward that the one I am working with.
    3. His amp is designed to Fixed station use, mine is +12 vdc mobile
    4. His design uses high input impedance devices that do not require toroid transformers thus allowing for dedicated bias controls for each transistor.
    I digested the circuit at http://www.ab4oj.com/dl/eb104.pdf along with the write up on the operation of the amp. I found it interesting that the boiler-plate design of the now commonly accepted EB104 based amplifer has bias voltage ran through a chip that controlled voltage level and current load but, the bias voltages for each device was paralleled from a single output. The final voltage adjustments for the individual devices were from a voltage dividers behind the regulator chip; higher tech voltage control but, same circuit that was used in the 1980's device.
    After some thought, looking at the Palomar TX-5300 circuit, I figured one way to install individual bias systems would be to
    1. Connect the base of the transistor to the impedance matching transformer via large .001 uf capacitors
    2. Isolate the impedance matching transformer from ground,
    3. Apply bias voltage through chokes to each base, behind the now DC blocking capacitor in the base circuit.
    4. I will leave the temperature compensation (wire a thermistor in) circuit for thermal tracking up to you guys to figure out.
    Just some thoughts.
    BTW: The .001 capacitors which are paralleled with the 15 ohms resistors in the base circuit is in error, they are not in the amplifier that I have; if they were there, RF drive would be divided / bypassed to ground.
    Don't forget to ground the B+
