Originally Posted by
kb2vxa
Oh, almost forgot one of the MOST important facts about CATV coax, aluminium shield so you can't solder to it. That's why installers use crimp connectors, usually an F and like RG6 quad shield and relayed lines ordinary F connectors don't fit. Still it's a cheap and dirty way to go, connectors, adapters and don't forget the stripper and crimp tool don't cost as much as"standard" cable and connectors for VHF/UHF work. Remember CATV cable has low loss up there because all signals are above 50MHz and up into the low GHz range. Unless you're running a kilowatt for EME you may as well clean off the couse while you're at it.
Yeah, hard line is best, etc., etc., which is why only well funded clubs and hams use it. If you own a TV station you can afford hard line.
