Results 1 to 4 of 4
Thread: Testing
    Ok....... Mike,you are testing a tower of some sort?
    Quote Originally Posted by VE7DCW View Post
    Heh... just checking on a reported forum bug. Cannot replicate it.
    Mine has more room inside and air flow front to rear with filtered air intake. OK, I just went through the jumping through hoops nonsense to post beach balls with teeth in the funny forum, let's see what happens here since it works normally once in a great while.
    A little larger than I expected, but as you can see you used up the once in a great while this morning.
