Results 1 to 7 of 7
Thread: FOX-1B Amateur Satellite.
    National Park N.J.
    I friend of mine told me he has been having fun working a ham radio satellite called FOX-1B, so I gave it a try yesterday. I made 3 contacts during a morning pass, that lasted about 10 minutes. I worked guys in Ohio, North Jersey, and Michigan. If you want to give it a try, the mode is FM. The uplink is 435.250 MHZ with a 67.0 tone. Downlink is 145.960. I was using an Icom 706 with a 15EL yagi for the uplink, and another 706 with a ground plane for the downlink. But, I read that it is possible to work it with a duel band HT on close passes. Go to N2YO.com where you can track the bird, and get a lot of cool info. http://www.n2yo.com/satellites/?c=18
    Cool George, satellites are a part of ham radio I haven't dived into much yet.
    National Park N.J.
    I used to play around with Russian RS-12, back in the 90's. It's dead now. 15 meters up, 10 down. SSB. Now it's just part of the space junkyard circling the earth.
    I have an FT-726R with HF, 2 and 432 modules, the full duplex Sat TRX board and a CW filter installed.
    A second one has 6, 2 and 440 modules plus a Piexx tone encoder. No Sat board or filters.
    Methinks I'm going to need another tone encoder.
    I've got a Yaesu 736r with 2m, 1.25m, 70cm, and 6 meter modules.
    I just need to put out my 70cm loop and I think I can make that sat.
    If they would have offered an HF module for that rig I don't think I'd own anything else. As it stands I think I've worked out how to convert one of my 726's 2M modules to 222. That will be a fun project.
    National Park N.J.
    I'm thinking about getting a dual band vertical. Trying to track this thing with a yagi is a real pita.
