Results 1 to 8 of 8
Thread: USB Memory Drive Letters
    Most of the USB memory sticks we use at home have drive letters assigned to them which is handy for shortcuts to open programs such as email. The letter stays regardless of which USB socket they are plugged into EXCEPT for a Kingston Data Traveler Elite 3.0. It's hardly new but 32GB in capacity. I can assign a letter but only for one socket, in any others it comes up as "K" which is the first free one. Changing the letter in another socket causes it to revert to "K" in the others.
    I've looked at System>Hardware>DeviceManager>USB>MassStorage (including "hidden") and removed them all and started again. From here you can find the location in "regedit" but I've no idea how to proceed.
    The nuisance seems to follow on any PC but as it's fast and robust I've ordered a DataTraveler G4 to replace it. This series seems to co-operate OK and I'll use the Elite for general purpose storage and transfer. The best way to avoid any more headaches I feel.
    Orca Whisperer N1LAF's Avatar
    Ledyard, CT
    Hugh, I found this website that may have something you are looking for:
    USB Drive Letter Manager
    USBDLM is a Windows service that gives control over Window's drive letter assignment
    http://www.uwe-sieber.de/usbdlm_help_e.html
    Conditions
    The software is not limited or crippled in any way. It's fully functional without a time limit. There is no "full version".
    USBDLM is Freeware for private and educational use only. Otherwise a licence is required per computer after a 30 day test period.
    "Educational" means institutions where the students outnumber the employees.
    Furthermore it's free for public, free of charge libraries.
    Thank you, I've loaded this, it's good and simple, the site has some other useful things too. Sadly it didn't fix the issue but I'll be using a different stick for email now. Looking at it using "Chip Genius" tells me the memory stick in question is a dual channel unlike the rest which are single channel. I recommend this if you have a problem, it gives the memory capacity and the controller chip.
    http://www.fixusb.com/chipgenius-software-2017/
    K is the new G.
    and A is for 'orse.
    And H is for hung likea......
    Hamster?
    Like that post was...
    Hung like a Norse?
