Results 1 to 10 of 15
Thread: I'm going to tap it tomorrow
    Kilroy08 W3MPS's Avatar
    Too close to Salem Island
    I just finished figuring out a design for a 40 db tap attenuator. However, I can't quite seem to find a definite answer to my final dilemma in the design. If you put two 1/2 watt resistors in parallel, the cumulative power handling capability should be one watt, correct?
    Ugh, It always seems like one project begets another.
    I picked up an old Radio Shack CB base radio for a friend, only to realize it has been goobered with. Well, I'm almost done de-goobering it, but now I have to make sure it's on frequency. Cool, my MFJ-269 can help. Wait, now I have to attenuate the signal lest I smoke something.
    Oh well, it is an excuse to make some nifty test equipment. Now if I can only find a decent used 'Scope for a good price.
    Quote Originally Posted by Kilroy08 View Post
    Correct.
    As long as they're the same value. The resistor with the lower value will pass more current and therefore the power it will dissipate will be greater than the higher value resistor, if they are different.
    Quote Originally Posted by N2KKM View Post
    As long as they're the same value. The resistor with the lower value will pass more current...
    Hmm, that's what I was afraid of. I'm mixing and matching to get the resistance values I need. I miss the old days when Radio Shack actually had a decent selection of components.
    I'll put it together and see how it goes. Eh, it is a prototype anyway.
    Guess I'll be ordering from Digikey for the revised design.
    5W or more carbon film resistors? Heck yeah, turn all the knobs to 11!
    DISCLAIMER: THE ABOVE STATEMENT IS NOT NOR DOES IS ADVOCATE GOOD AMATEUR PRACTICE AND AS SUCH SHOULD NOT BE TRIED AT HOME.
    Thank you everybody for the input, I'll let you all know how it turns out later today.
    Precision metal film resistors no option then?
    Test them by measuring the surface temp... that will help "match" them.
    Like Ouch! hmmmm, ouch! ? :rofl:
    Ooops, too much info...
    Well, it works. Hooked up the tap and my 269, all channels were spot on and no blue smoke came out. I'd say I had at least $30 worth of fun putting it together and trying it out. The hardest part was finding the SO-239 connectors at Radio Shack. They were re doing the whole component cabinet and everything was in a huge cardboard box. As luck would have it, they were at the very bottom of the box.
    Precision metal film would be the way to go. When I get around to ordering parts for the real deal, I'm going to say screw it and get the beefiest capacitors Digikey offers. Not that I would want to attenuate a kilowatt down to safe input levels for test equipment, but if I build something I'd rather over engineer it a little.
    For a little screw around project, I'm quite pleased. I wouldn't want to put more that 30 or 40 watts to it, but it did what I needed it to.
    Kudo's to you ;)
    Tiki Bearer
    Jan 2011
    y u want 40db?
