Results 1 to 9 of 9
Thread: Needed: Good amount of Coax, and a good amount of wire
    Tiki Bearer WA7PBE's Avatar
    Apr 2014
    Classified
    Im looking to aquire some coax about 30 ft or so and some wire (preferably about 12 gauge, im trying to make a discrete atenna) about 85 ft worth. I don't really have the money to purchess retail because my son is due any minute now and times are tough. I can make really good cookies! I'm kidding (but i will send you cookies) but i was hoping to work out some sort of deal whatever it may be.
    At 30' you can do the skinny coax and be OK. Just make sure it has good ends.
    As for the radiator part of the antenna. Try to scavenge some CAT5. I see that stuff everywhere these days as people are discarding it left and right.
    Apr 2014
    Classified
    i just need coax for a 2m antenna like the one in k7age video
    https://www.youtube.com/watch?v=HkmD3Sgz7Q0
    You can usually find CATV coax in the garbage. You'll need new ends.
    As for the wire for the antenna: Any wire will do. Even lamp wire, speaker wire, etc etc. If it conducts, it'll work.
    Quote Originally Posted by WA7PBE View Post
    Until you get more material, try this antenna (It works great, BTW. I made one 5 years ago, and still use it): http://www.hamuniverse.com/2metergp.html
    It'll cost you $3 for the SO239 connector.
    Apr 2014
    Classified
    its the exact same antenna pretty much, i already have the connector too.
    "They" say, "Life is too short for QRP...
    but in reality, it's often too short an antenna.
    With a bit more material, you can homebrew a vertical
    that can effectively quadruple your radiated power.
    http://www.hamuniverse.com/2m440collinearvertical.html
    And especially on 2 meters, the importance of low loss cable
    cannot be stressed too much. Thirty feet of "skinny" RG-174
    can soak up over half your power. Cable companies buy large spools
    of lower loss cable, and often discard short lengths. It's 75 ohm
    (instead of 50) but "close enough for government work." ;)
    I can send you some coax, and some solid copper wire for the radials if you are going to build the 1/4 wave antenna using your coax connector. Where do you want it sent?
