Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: how do I break a stuck screw and other questions
  1. #11
    Re: how do I break a stuck screw and other questions
    There is a type of Phillips driver which has serrated edges on its flats for a better grip. Sears sells them, and I'm pretty sure that Snap-On and Mac/Matco do as well...
  2. #12
    use a gas pliers or if you dont have one a water pump pliers.
    grab the jewlers screwdriver with it onb as shallow an angle as you can to give maximum down ward pressure.
    the the trick... give the pliers a SHARP twist.. the sudden snap should break the screw loose. I have done this many times on printers, fax machines, dictation equip. radios,..
    effectivly its a 'one shot' impact wrench.
    The gas pliers helps as its jaw is rounded on the end too. where a water pump pliers is flat on the jaw.
    if you look at the end of a gas pliers ,it looks like someone drilled a hole down the end plane.
    a water pump pliers ,looking at the end , is just two flat planes.
    water pump pliers is the basic, generic, farmer inthe pants pocket pliers.
  3. #13
    National Park N.J.
    Quote Originally Posted by KB3LAZ
    Quote Originally Posted by ad4mg
    Honestly, and I know from experience, a top dollar screwdriver will bite harder and is less likely to strip the head out. A Snap-On phillips-head of the proper size should do the trick, especially if you have a buddy who has the complete set of Snap-On Precision screwdrivers. I have a set, and they've saved my bacon many times.
    And, if you can find a can of "PB Blaster" penetrating oil:
    That stuff is the real deal ...
    Works on frozen (I mean literally) carabiners.
    Yeah, but does it come in strawberry flavor?
    :drool
  4. #14
    Fertility Shaman N5RLR's Avatar
    Dallas, TX USA
    How does PB Blaster work on ~15-year-old exhaust-manifold fasteners that probably haven't been popped loose since the car they're on was built? I may have a need... :think
    73 de Mike, N5RLR
    "I drink for the honorable purpose of getting bagged." -- Jackie Gleason
    "It is my belief...that the truth is generally preferable to lies." -- Albus Dumbledore
  5. #15
    Island Regular
    Nov 2008
    Des Moines, IA
    That is exactly what the stuff was designed for! If PBB can't break it loose, your next option is breaking or cutting! I'd soak them down the night before you need to wrench on them and let the oil soak into the threads, but I have had really good luck with that stuff... It seems to just dissolve rust.
    John (N9MXX)
  6. #16
    Master Navigator AE1PT's Avatar
    Upstate New York
    For radio work, it is always a good investment when buying quality bench tools. Several companies make very nice multi-bit jewelers sets that go on a single shaft that is designed for applying a little more downward force and horizontal torque.
    A standard trick is to place a driver bit that properly fits into the screw into the head, and gently tap the bit a few times. This can also be done with a single unit screwdriver. The tapping will loosen various oxides in the threads--and at the same time improving the seating of the bit by reforming the cross of the head. Then attempt to remove the screw.
    Worst case analysis is that you wring off the head, and end up drilling out the hole or finding a new way to secure that part of the case...
    Give a man a fish, and he will eat it. Teach a man to fish and he will spend lots of money on tackle...
  7. #17
    The People's Republic of Kalifornia
    I second both recommendations, That penitrating oil is the Bee's Knees.
    Nothing beats a good set of Snap-On screwdrivers. :)
    Best money I have spent on tools.
  8. #18
    Quote Originally Posted by N2NKW
    OK Cool thanks guys. I willl try to find a bigger screwdriver. Only problem is the screw is sunk in the fram so I dont know if a standard size screwdriver will fit. Them screws is itty bitty things! I'll see if I can find some of that breaker stuff. gotta be careful though, I'm out of work and dont have a lot of disposable income anymore..lol
    Make your choices carefully, you only get one shot at success.
    I have seen techs twist off screws holding power transistor flanges in place because they believed in BFFI.
    Bruit
    Force &
    F*(king
    Ignorance.
    The same guys also make crappy dates.
  9. #19
    Island Regular
    Nov 2008
    For what it's worth - a drop of tincture of iodine will often loosen rusty bolts or nuts. Just put a drop or so on, let it soak ovrnight, then try it. This has worked for me using the dark iodine. Haven't tried it with the clear iodine.
  10. #20
    Nov 2008
    arnoldsville ga
    pb blaster is good but kroil or aerokroil put it to shame. another trick it to try to ever so slightly tighten them. this will break loose any threadlocker that might be on them.
Similar Threads
  1. Antenna Stuck in tree
    By n2ize in forum Antennas
    Last Post: 02-08-2010, 12:46 PM
