Results 1 to 9 of 9
Thread: Icom 718 weak receive
    My Icom 718 took static/lightning hit? Transmit is fine but receive is weak. Maybe gas discharge tube is bad, or other filter board part? How do you check a gas discharge tube?
    Sorry for not noticing this before.
    A GDT is not in "series" with the receiver's front end. Rather, it's shunted to ground and will conduct excessive voltage to same when its breakdown threshold occurs.
    I have a 718 plus servicing info. What do you have in the way of test equipment?
    Thanks, I have the usual fluke and access to an HP spectrum analyzer and a portable O Scope. Also have a nice shop at home and at work.
    Any sort of RF generator?
    That I do not have. I suppose I could use another low power rf generator of some kind, or throw one together out of the parts box.
    I'd look into a NanoVA or similar low-cost signal source. An amplitude/frequency stable unit is going to be very helpful in troubleshooting things.
    Gping through my stash of old equipment, I did find an ancient Eico grid dip meter.
    That has AC on the chassis, depending on how you plug it in. Steer clear for DC-powered equipment.
    Yep, it does have an AC cord.
