Results 1 to 8 of 8
Thread: New amplifier bought
    Retiring the Heathkit SB 1000, just ordered he Acom 500 S, 500 watts 160 to and 4 meter amp, solid state amp.
    Why? never used he Heathkit above 5 to 600 watts, and he new amp does 6 and 4 meters as well where i'm quite active.
    I now replaced all antenna's and gear for new and hope they outlast me ;)
    Cost here with cable for Yaesu FTdx 10, 2800 euro, pricy but beter buy good first time 3 year warranty as well.
    All antenna's are witthing 1 : 1.7 most far below 1 1;5, homebrew 6 and 4 meter are 1:1.0.
    Congrats, Cor!
    IMHO, 500 watts is the sweet spot for amps on a dollars-to-dB basis.
    `Just a tad over 6 dB, or 1 S point, but reliable and fool proof ;)
    For the next 6 dB you need 2000 watts...
    Not to mention a significant number of extra dollars/Euros, which is why I think that 500W is the amplifier sweet spot.
    Smashing that like button!
    Like that post was...
    No difficult choice most antenna's here can handle 1500 watt SSB, are on or below 1:5 SWR, so no tuner needed bar the vertical for 160 that has the MFJ 998 legal limit tuner feeding it at the base, used from 160 to 17 meter.
    For 6 and 4 meter i use the home made cat whisker dual vertical dipole swr 1:1
    or for 6 meter the Fritzel FD-4 off center fed dipole of 130 + feet.
    We'll see what happens even with the Heahkit SB 1000 i mostly ran 500 to 700 watts.
    Ease of use, amplifier follows the FTdx 10 in band change, so much more user friendly.
    Got word amplifier will be delivered from factory in Bulgaria to dealer next week, so week later it will be here.
    arrived and installed, FTdx 10 only needs 8 watt drive for 200 watt out, or 20 watt for 500 watt out.
    Quiet fan, you can hear it spin up though on full power, mostly i am on 6 or 4 meter running 200 watts.
    I am surrounded by LCD screens now....
