I take it you've done this before.
I've enjoyed island life for 17 years. That's 13 years more than the Confederacy was around.
RIP Albi
It's a jungle out there. Many EQ stupidly with poor articulation.
~TKX
YIAH
"And, of course, the Gym Teacher being his usual self."
W3WN
"The enablers ride on the top of the pile."
WZ7U
That's no fun if you don't have a lift.
Manual should be a breeze. Not that I've done one. I have not. I can only rely on what the locals say.
RIP Albi
~TKX
YIAH
W3WN
WZ7U
I had the same transmission in my 70 Challenger. Nothing odd in it other than the oil pump (front two gears in constant mesh have 3 holes drilled into the counter shaft gear) and the fact that for the cars you use only ATF. Even on my 440 sixpack. Truck might be different. And check your shift forks, I had one break off on me.
I thought religions were prophet based organizations.
What do you mean I am out of money? I still have checks!
Remember, amateurs built the Ark, professionals built the Titanic
I also had a aluminum OD and bell housing in my 64 Valiant slant 6 conv. Put it in my self. Never had to pull it apart. The cast iron one I did rebuild. I did think long and hard about putting OD gears in the Challenger (4:10 Dana 60) but it is a numbers matching. Not so much the 64.
