Results 1 to 10 of 11
Thread: Solar Cycle 25 has started
    Volcano Tamer N1LAF's Avatar
    Ledyard, CT
    This is the 3rd consecutive month that Solar Cycle 25 sunspots have appeared: Nov. 2019, Dec. 2019, and now Jan. 2020. The quickening pace of new cycle sunspots does not mean that Solar Minimum is finished. On the contrary, low sunspot counts will likely continue for many months and maybe even years. However, it is a clear sign that Solar Cycle 25 is coming to life.
    https://www.spaceweather.com/
    Volcano Tamer PA5COR's Avatar
    There's always 160 meter where i'm active most of the time, groundwave reached 100 miles.
    Im not liberal/conservative, Im anti-idiotarian.
    Ah but you're right, cycle 25 has begun, but one blackhead on the face of the sun is not a portent if the last two slow start cycles are anything to go by. Meanwhile 160 and 80M are good for rag chewing and with the right antenna DX can be amazing. That antenna I keep advertising is the grounded vertical folded unipole that gives the needed low vertical takeoff angle impossible with any other that come to mind.
    On edit, on the Space Weather page the first thing that grabs attention is the day late announcement of the meteor shower last night worth staying up for. It brought to mind the fun I had on 6M with the Leonid shower a few years ago. They're workable on 2 with high speed data bursts, but on 6 they're long enough for a two way SSB exchange, and long ones good for two and sometimes three contacts. So, did anybody work meteor trails?
    The left moved to the center, the right moved into a mental institution, and in 2016... I'll let The Specials finish this.
    "New Jersey, the most American of all states. It has everything from wilderness to the Mafia. All the great things and all the worst, like Route 22."
    Jean Shepherd K2ORS (SK) & WOR radio personality
    If you want to fly with the eagles don't run with the turkeys.
    Akron, OH
    Move to the upper HF portion of the spectrum and play with Es if the spots let you down. It would be nice, though, to get some F-layer skip on those bands.
    That's why I always had a rig tuned to the 6M SSB calling frequency, that's where openings usually start. Please pardon my bragging rights being I'm a DX magnet and have worked every propagation mode on 6, no lie. Here's my best DX on the magic band, if I hazard a guess it was rare F2 entirely possible at the peak of The Millennium Cycle. Go for it guys, since E is caused by UV independent of sunspot activity it can happen any day, but best in summer so watch the UV index in WX reports.
    Master Navigator kom's Avatar
    Quote Originally Posted by N1LAF View Post
    Actually, you might be a little late (better than never) to the show.
    https://forums.hamisland.net/showthr...318#post667318
    Master Navigator
    Sep 2012
    The latest semi-scientific wild guess is that this cycle will actually be a little higher than the last one. Hurray if true! Last cycle, 10 meters wasn't great most of the time. 12 meters was more like 10 ought to be. Maybe 10 will return to it's daily DX glory again. We can only hope! There will probably be a few instances of 6 meter F skip, too, as there were in the most recent depressed cycle.
    I hope people play with 15 and 12 while they're waiting for 10 to light up. 15 has become a very underused band, and it's a shame. Propagation is almost as good as 10 for DX, and usually opens up at least a year before 10. Last cycle, on many days, about all I heard was DX on 12.
    Wasn't too bad on 10, worked all continents on 10 last time, Japan, etc all included with 100 watts into a old Imax 2000 vertical.
    Same antenna was used on 12 and 15, did quite nice there as well.
    "15 has become a very underused band, and it's a shame."
    Most of the time I'd agree, but my experience with it under an Amateur Extra license says at the peak of a cycle it opens at sunrise and closes around 2am.
    "Propagation is almost as good as 10 for DX"
    That's where I disagree, it may be a bit less crowded but the target areas remain the same. I don't know about 12m, back at West Creek the 160m sloping open delta was deaf below 20m and tuning on the grounded vertical folded unipole became too narrow and tricky below 40m to be usable. Otherwise a 20-15-10m beam up 60ft did the work.
    COR, you must be the master of understatement. 15 and 10 get so crowded with JAs it's hard to find rare DX that's sandwiched in. There are more hams per square kilometre in Japan than any other country in the world, they take over. I don't consider them as DX and went shooting for Korea, China, and Southeast Asia. Then I played a little mind game with them, when they asked "What are your working conditions?" I replied "Not good, I'll register a complaint with the union.". That left a long pause as they pondered and were too proud to ask "QLF?". What happened to "What equipment are you using?"
    100W is quite enough for all around working, it shines with DX and that's all most of the world uses. The big guns don't do any better except in contesting, I don't consider working with 1500W PEP output Amateur Radio, it's more like professional broadcasting. It's wasted energy and making the electric company happy. With a Drake TR-4 and 3el tri-band beam at 60ft I worked the world. One time and one time only I fired up the Collins station with a 30S1 kilowatt kicker in a futile effort to break the 20M Kalifornia Kilowatt Kurtain. (Gee, another KKK! hi) Going back a few decades, I did a very simple mod to a Hallicrafters CB3A and worked QRP with Georgia CCCP with a bootleg callsign. <blush> It goes to show how one can work DX on 10 with 4W AM into a non-resonant vertical, or to use a couple of old expressions, using a wet noodle or loading up the bed springs.
    Completely aside, has anyone noticed that Robby the robot has a built in direction finder?
    Working JA's from Europe or the USA has a difference.
    If Conditions over the Northpole are open, easy, if not more difficult.
    I ran the Yaesu FT 847 then with Collins filters, 100watt then my Heathkit SB 1000 was then in full repair mode, total overhaul.
    Now using the FT 2000 D 200 watts, and if need be Heathkit SB-1000 that has been stuck on 160.
    It will work on 10 though, but i noticed i never needed more as 200 watts on 80 - 10 to make reliable chats.
    Mostly there i use the "improved" FD-4 with coil and extension wire for 160, or the 160 vertical tuned by the auto tuner.
    Living on the edge of the town, noise is low S3 on 80 and S0 on higher bands.
    Foreigners that don't have English as first language, give them some slack
    My English is as German passable, Frisian and Dutch quite good as first languages, french so so...
