Results 1 to 8 of 8
Thread: Rig Blaster Advantage Question
    Tribal Warrior
    Nov 2013
    Hs anyone tried The Rig Blaster Advantage? Looking to find out if it's worth the money or should I look elsewhere? My Signalink is old and tired and needs to be replaced.
    The fall of this country will not be at the hands of a foreign enemy, but at the hands of the ignorant and uneducated of this country.
    Newbie
    Oct 2017
    Eagle River, Ak
    Been using one for a number of years now. It has never given me any problems.
    I use kenwood, icom & yaesu radios with it, the little plug in board they have
    makes it easier to switch the unit between different brands of radios.
    Here's a topless view ...
    Attachment 16625
    73
    AL7JK
    Tribal Warrior
    Nov 2013
    Thanks I bought one.
    Master Navigator
    Sep 2012
    The nicest thing I can say is that they have excellent tech support, and I needed it to figure the beast out. Once it was working, it was just fine.
    Tribal Warrior
    Nov 2013
    What did you have trouble with?
    Master Navigator
    Sep 2012
    I had problems getting it to key the transmitter as I moved from different modes to each other. I had it set to do 'hard' keying, but ended up using 'vox' instead for everything. It just didn't seem to make logical sense. I had it explained to me, and it made sense, but I soon forgot the explanation.
    Tribal Warrior
    Nov 2013
    I have the Rig Blaster up and running. I did have a little problem with it, but it was on my end and not the interface. I got everything installed and I could see the signals on the waterfall, but it wouldn't decode. I played with it for a couple hours and still nothing. So, I left it for awhile and did some other things. I came back to it a couple hours later to try again. I was watching the waterfall and the signals seemed to be a little off. So, I resynched the clock and bang. It decoded like a champ. In fact it's decoding signals the Signalink would have missed. The software sets up the computer comms and makes the WSJT-X setup really easy. You just pick the Rigblaster for playback and record, set the levels and you're done.
    Cool. I have two RigBlaster Plug-n-Play units.
    Both are for Yaesu (FT-857/897) that work great.
    I have a simple cable adaptor for my TS-850.
