Ok... I've completed a bunch of ham radio projects in the last 3 days:
1. APRS station: Completed.
2. sql logging solution running and replicating.
3. Installation of RAID enclosure in main network server for backup and failover.
4. 220Mhz beam up and working.
5. All coax is now LMR400 flex.
6. Alinco DM-30t Power Supply modified for better cooling and quieter operation.
7. RAID enclosure modified for better cooling and quieter operation.
8. Apache Labs ANAN 100D configured with internal oscillator turned off- GPSDO fitted with active antenna. Un-Frankenstiened the crappy connectors used and replaced with new ones.
9. Soldering stations recovered from storage and being used.
10 Reflow solder on badly manufactured 19 amp Radio Shack power supply.
What should I do next?
1. Clean and sort mess on bench so things are findable.
2. Run coax to 2 meter horizontal loops and do some weak signal.
3. Remove transformer from Radio Shack power supply, dip in lacquer to get rid of hum, buzz, whistle.
