Results 1 to 4 of 4
Thread: Winter VHF/UHF season...
    Well guys, we're into the short winter season which runs through the first week of January.
    I'm working repeaters across Lake Michigan quite often.
    Here's what last weekends opening looked like plotted form my APRS node:
    That's good enough for some weak-signal work at the bottom of 6 and 2.
    Park a 6M rig on 53.170 and give a listen. Can you hear that machine in your neck of the woods, Mike?
    Dunno... noted it and will try.
    That's Marty's (N8XPK) system. He's one of the locals...motorcycle and 10M crew in addition to a lot or repeater building and maintenance. I monitor the system; try giving me a call if you can bring it up. I think the PL is 110.7, but you may need to verify via the Repeater Directory.
