Results 11 to 20 of 24
Thread: 6 Meters, Wooo Hooo
    Had a blast listening to the 10 meter repeater outputs from New York...
    I can bring a full 100w to the 10M FM party with the FT-980s here - they're rated for continuous service at that power level in all modes. The next big trick is to fit a CTCSS encoder to one.
    Should the band really shorten up in a big opening, give a listen on 29.640. That's the Salem machine - about 30mi east.
    I hunted around for the tones for various NY 10 meter repeaters but was not able to get into any.
    Next time 10 is wide open I'm going to make another attempt.
    Most 10 meter local simplex/repeater use is mobile to base therefore, vertically polarized. They tend to kick on the tone squelch when the band is up. There is always a boomer from New York on 29.62, but there used to be an awesome St.Thomas, V.I repeater standard 52/62 offset. Where I live when 10 opens up, it is usually the bottom half. When 10 is up for summer time top half, I start scanning 6 meters. I love the local cross band repeaters with the 10M link. It is fun to open the link, and work fm dx with a walkie talkie on the machine. Call me old phart, but I do not qsl a repeater contact, but will a satellite, am I a machine racist?
    A couple of days ago, 6 meters was open and 10 meters was hot. Just for the heck of it, I used a "wet noodle", (a Hustler mobile antenna with a 15 meter load on it that is also resonate at 50 MHz, mounted on my porch) to made my first 6 meter contact on FT-8.
    I dropped down to 10 meters, changed to my di-pole and made some hook ups there.
    National Park N.J.
    There was a nice 6 meter opening June 19th to the West coast. I also heard a a guy in Georgia work a KL7 in Alaska. I did work 3 stations in Arizona. Picked up 2 new grids. On the 20th it was open into Canada around Prince Edward island .
    National Park N.J.
    I put up an m2 loop for my backyard station. It works very well. https://www.dxengineering.com/search...torder=Default
    I have a Moxon beam ordered for my station in the shack. Hopefully, I'll have it up and running for the Sept VHF contest.
    Woke up to this on 2 meters this morning:
    National Park N.J.
    Dayum!
    Wowsers.
    Still kind of going on.... picks up at night then wanes a bit during the day... hope it keeps going.
