Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Primer or Howto for Repair of Hybrid HF Transceiver
    Some progress made...
    An amateur friend and I have been investigating the problem. We discovered that the power transformer seemed okay. Also the various diode bridges seemed to test out as they should. On the HV line there are two 47uF electrolytics in series, each with a .01 cap plus a 470k resistor in parallel. A few fuses later we checked the state of the electrolytics ... and the first is a bit of a dead-short on the ohmmeter. At the same time there are spark discharges and another fuse blows!!
    I've ordered some new electros off the 'net and they will be fitted when they arrive. getting new electro was not an issue (450VW) but they are pcb type ... not the chassis-mount originals. We will probably just remove the old electros ... and mount the assembly on a 7-way tag strip screwed to the radio chassis. I am conscious of the need to maintain air-flow and NOT blocking up holes.
    More details after our next session.
    richard
    VK1RJ
    If you're repairing a '530, have a look here (about halfway down the page):
    http://www.k4eaa.com/parts.htm
    Since the thread started I managed to acquire a TS-530SP, two TS-830S "Gold Label" units (one a project rig) and enough spare parts to make things...interesting. Look at our "Mods and Repairs" area of the site. I'm going to start a mod/upgrade thread for both rigs. There's common DNA between the two (PSU, RF, PLL and Counter Boards, final assemblies) and many of the mods destined for one will work for both.
    Beach Bum KA2PTE's Avatar
    Aug 2020
    Veryork
    On the recapping idea, surprisingly I see in lots of older gear the Elna capacitors are used and they hold their values pretty well even after 35 yrs or so.
    When I worked the 830S low voltage power supply section on the AF-AVR board I checked the caps and the only one I saw obviously shot because it leaked electrolyte was C9 so I replaced it.
    Others I checked showed ok so I gave up checking them all. I see the 530 also has this cap C9. Looks like maybe part of the 1st buffer after the balanced modulator if I read it right.
    KA2PTE, Hello and welcome to The Island. As is custom, your introductory tiki drink.
    Aug 2020
    Veryork
    Thanks for the welcome KG4CGC.
