Page 3 of 3 FirstFirst 123
Results 21 to 30 of 30
Thread: New tires
    I forgot about that one... TPMS = Tire Pressure Monitoring System. Have one of those go bad, and the valve stem replacement gets expensive.
    Cutch 2K!!
    How much per sensor on the average car?
    Try $180/wheel on my bikes.
    We had to replace one on the Boss's 2009 Mazda a couple of years ago. It was in the neighborhood of $80-85.
    I remember the mechanic telling us that some people had gotten irritated with the things, removed them from their tires, found a way to set the things to always report the "right" pressure, and tossed them into their trunks. Sounds like a few people we know...
    Cutch 2K!!
    Island Regular
    Mar 2017
    VA
    Yes. I have read about people taking pvc tubing, cap and seal the ends with a valve stem in 1 end, drop them all in there, pressurize it to 32psi, and throw it in the trunk.
    Dan - N3XJN
    <this sig is under construction>
    What tire(s) would you recommend for a 350 pound sport bike with a 200 pound rider? Currently the bike comes from the factory with bias ply tires but they tend to pull you into the groves in the road.
    Master Navigator ka4dpo's Avatar
    Right Here
    Dunlop or Yokohama both make really good motorcycle tires, Michelin does too but they are more expensive. Dunlop are soft compound and very grippy but wear quickly, they also track much better than the harder compound tires. It's a tradeoff between grip, handling , and expense to replace them more often.
    We never had weather like this before they started messing around with that internet stuff.
    Yeah, that's pretty much the dilemma. I was wondering if you'd go with a nylon tire if it came factory with bias ply.
    PSA: Don't forget to check the air in your spare tire!
    Flat happened Late Monday Afternoon.
    I received an indication that I had low tire pressure but, before I could remedy it, I had a complete tire failure. Called Road Service and had them come out to change it (couldn't get the P.O.S. factory supplied jack under the frame of the car). Road Service guy said, "You better check the pressure in your spare", it was down to 10 psi; what can you expect when, the spare tire has been in the trunk for seven years untouched?
    Went to "Tire Discounters" on Tuesday Morning, they didn't have a 175/70R14 sized tire in stock so, they had to order it from the "Warehouse". I ask, "How long will that take?" Answer: "We can have it in by 12:00 tomorrow (Wednesday)." I could not get there until after 5:00 p.m. Wednesday; waited an hour and a half for them to get me out the door. Drove on Donut spare for 2 days!
    Only $55.00 for a 40,000 mile tire for the Hyundai Accent and, another 25 bucks for for balancing, mounting disposal of old tire.
  9. #29
    Back when I had the FZ-750, with a hard to find 14" front tire.
    I had good luck with these:
    https://www.totalmotorcycle.com/phot...arracudaVC6000
  10. #30
    MOT done yesterday, 24 Euro's done, no repairs, just the check and notifying the bureau for result, done till 15 dec 2018.
