Results 1 to 10 of 15
Thread: Fedora + Grub Menu Gone
    I am on Fedora 25. The other day did a few system upgrades to keep everything up to date. Usually on initial bootup I get the Grub menu that appears on screen so I can select which kernel I want to boot into, whether I want to boot into rescue mode and/or whether I want to add any specialized boot options. Suddenly I am not getting that menu anymore. It just boots into some kernel and eventually takes me to the login screen, Any ideas ? I'm not too familiar with GRUB troubleshooting... in the past it always just worked. Has anyobne else experienced this and or anyone familiar with diagnosing the GRUB boot loader ?
    Island Regular
    Mar 2017
    VA
    Haven't updated mine in 2 weeks, probably should, but...
    Sounds like some (technical term alert) linkages got screwed up (ok, another technical term).
    Not too familiar with the whole GRUB / boot process, like you said it just always seems to work... and when it doesn't.. oh crap!
    Which kernel is it booting into? The latest you updated too?
    uname -r
    should give you the version.
    If you use IRC, you can try asking in the #fedora groups.
    Dan - N3XJN
    <this sig is under construction>
    You may have to wait a bit since most of the fedora group members are out getting their chapeaus dry cleaned and re-blocked
    Quote Originally Posted by N3XJN View Post
    uname -r
    It's booting into kernel "4.10.16-200.fc25.x86_64". You're right, I might have to ask around on one of the Fedora tech forums or chat groups.
    LOL..
    It looks like the nowait, along with the splash kernel option got passed to the grub conf, during an update.
    So what would be my best option ? Should I change those settings in /etc/default/grub and then run "# grub2-mkconfig -o /boot/grub2/grub.cfg" ?
    I "think" so. It's been quite some time since I've played with boot options (Just make it work).
    Island Regular
    Mar 2017
    VA
    Ok, I'll admit... I had to look up what a "chapeaus" was. lol
    Dan - N3XJN
    From what I can tell my configuration looks correct, I can't find anything that would cause the boot menu not to show up on-screen. In fact when I am booting the machine it pauses at about the time the menu should appear and it seems as if it's trying to show the menu. I see a black screen and a small white prompt and the monitor seems to change resolutions but no boot menu ever becomes visible. Then it just times out and boots into whatever kernel is set as the default.
    Actually it's not that terrible of a problem. Since this system only runs Fedora Linux I don;t need the boot menu for selecting between different operating system. All I need it for is to select which installed kernel I want it to boot into and there are other ways to do that without a boot menu... So I can live with it like this but it would still be nice to get it running right and show the menu again.
    P.S. I have a similar system in the next room running Fedora 25 as well. I can take a look at those configuration files and compare them with the ones on this system to check for any discrepancies...
