Results 1 to 10 of 21
Thread: Question on mounting 2m antenna on plastic big rig
    Somewhere in Murica!
    Been having a helluva time trying to install a 2m antenna on my Freightliner Cascadia. I know we got a few current/retired drivers here hopefully can help
    What I have is basically a plastic truck. It's all composite materials or outright plastic. As it is a company truck, I cannot make holes or modify the truck in any way. There are no West Coast mirror frames so I am using a Wilson mount to attach to the plastic foldover mirror frame. This frame is all plastic and has no bonded connections in it anywhere to help make an antenna work right. there is nothing to bond to inside the frame and the rest of the door is composite material. This poses a problem.
    What can I do to mount a 2m antenna? So far, I've tried Hustler SF2 5/8w antenna with no luck. Tried a Half Wave with no luck. Both failed due to needing grounding/bonding to the truck, which I can't do
    I have been trying to look into "no groundplane 2m antennas" but can't find any info on whether they will work on a plastic truck. I know the theory but can't find any sort of explanation or construction history on how these work.
    When the term Ground Plane is used, are they speaking of having a grounded bonded connection to the body/frame of the truck? or are they speaking of having an actual ground plane attached to the antenna? Will a "No groundplane" antenna actually need no groundplane or any sort of grounding/boding to the truck to work? If not, then what is the idea on how they work? To me, the term "No Groundplane Antenna" is an antenna that will work in free space without any sort of grounding, bonding or connection to any sort of metals.
    As it looks like most of these type of antenna are 1 piece units, How do they balance out? Is the coax shield the other half of the antenna or is something else at work here? If so, does this mean I have to use a "tuned" piece of coax to provide the counter to the main antenna? Half wave at 146mhz is about 39 inches and thats a way short piece of coax to use in a mobile instance.
    Help would be appreciated. My GoogleFU is weak today.
    Thanks
    Everyone of those antenna's needs a groundplane, one wire of about 50 cm running at a 180 degree angle will do, otherwise the coax will be used as ground plane.
    That is less good, so if it is possible at the antenna feedpoint to connect a 50 cm wire do try so.
    What we did in plastic top cars was glue in a 50 cm x 50 cm square aluminium foil and use that as ground plane but you can
    't drill holes in it, so that is out.
    Ohh, I gotta noodle that one for a while. I bet there is no way to have a dangly piece of wire as a counterpoise, is there?
    Off to think about this....
    Look for a wire with isolation in the colour of the mirror, tape it with same colour tape to the mirror frame.
    That way it won't be a real eyesore, needs to be only a thin wire anyway, so you are making an open dipole with it with the wire acting as 2nd half of the dipole.
    Does your cab have an air dam overtop it and the sleeper?
    I drive a "condo". I have a dome but not an actual hollow air dam. Wish I did as I could just wind counterpoise all over it...lol.
    I think I'm going to try COR's suggestion and try to add counterpoise on the actual mirror housing frame.
    Unfortunately, the mount style I'm stuck using is too small and oriented 90° the wrong way. Plus the jpole needs space around it and it would be right next to tge cab so it wouldnt work. The tuning stub would ne the issue
    Conch Master W7XF's Avatar
    DM42kj
    FreightShakerCascadia? Dunno about that one, due to the ground (?) being all about non-existant. The best attempt I'll guess is to mount it to the frame rail on the left corner of the back of the cab. At least you'll some semblance of a ground. Of course, YMMV.
    Yea, too bad. I have that Arrow antenna, and it kicks ass.
    Build a twin lead jpole and stuff it in some PVC pipe?
    I've built/elmered these for new hams
    Suspend it inside of PVC with some fishing line.
    http://www.qsl.net/wb3gck/jpole.htm
