Results 1 to 8 of 8
Thread: Trust Wouxun's KG-3 programming software?
    I would like to transmit out of band (150+MHz), can you trust the programming software available on the net supplied by wouxun? I simply don't need a expensive brick! Thanks for any thoughts..I love the KG-6. WD8MMN...73
    Why do you want to transmit out of band?
    Tiki Bearer
    Jul 2008
    In Jersey somewhere
    Probably wants to xmit on the Marine Band.
    He attacked everything in life with a mix of extraordinary genius and naive incompetence, and it was often difficult to tell which was which. - Douglas Adams
    Quote Originally Posted by KF2M View Post
    Speaking as a ham who lives on a sailboat, I'm not going to help him do that.
    Marine VHF radios are required to be FCC type-approved. In addition, Wouxun and other inexpensive Chinese HTs are know to have significant problems with spurious emissions. On the ham bands, this is merely annoying. On the marine VHF band, it could be life-threatening if it causes interference to an emergency call.
    Quote Originally Posted by WD8MMN View Post
    If you think a new Wouxun is expensive, you should check out the price the FCC charges for illegal operations!
    Also, I do not believe I've seen an expensive Wouxun. I figure, at worst, give it a whirl. Which software "on the net" are you referring to?
    Anyway, first impressions are telling?
    Vertex/Standard/Horizon (Yaesu) offer a nice marine-band HT with the same form factor as the VX6-VX7. Batteries and other accessories are interchangeable and AFAIK it can be set up to transceive on the 2M amateur band.
    Get yourself one of those if you're planning on operating on the VHF Marine allocation. Either by itself, or in combination with the VX-series HTs I mentioned. You only need take one charger and peripherals for both.
    Something to do with being a rent-a-cop maybe? The premise sounds fishy to me. Perhaps if the OP elaborates a bit, a more reasoned response is possible.
