Results 1 to 10 of 14
Thread: Heath HD-1234 Connected two radios to one antenna
    Newbie
    Oct 2016
    SC
    I'm thinking YES on this but, I wanted to be sure. I have a Heath HD-1234 coax switch. I want to connect two radios to one antenna. Is this ok? I have the manual and, it shows using two switches to connect multiple radios to multiple antennas. It is rated for 1000 watts. See attached photo. I'll connect the antenna to "C".
    It's risky. Given the sensitivity of modern radios and the isolation on most of those switches, you could end up blowing out the front end on your receiver(s). Better to build a patch panel.
    Ditto on the patch panel. Not enought isolation to keep harmful levels of rf from one radio getting into another.
    Boy, I'm glad you asked first. Imagine how mad you would've been
    Orca Whisperer kf0rt's Avatar
    Denver 'burbs
    The HD-1234 grounds all unselected SO-239's. As long as the switch is grounded, shouldn't he be okay?
    Quote Originally Posted by kf0rt View Post
    Theoretically, yes, but it's a DC ground for lightning protection/static bleed-off and we all know that the behavior of AC at radio frequencies often does not conform to what one expects in a DC circuit. It might work just fine; on the other hand, it might not. IMHO, it's not worth risking the front end of a receiver.
    Denver 'burbs
    Good point, though I guess I've never seen a problem with it in practice. Best not to risk it.
    And heya, Carlo!
    The one way you might safely get away with this - assuming the antenna is a multibander - is to use bandpass filters at the antenna connector of each transceiver, with a band-stop filter at each port of the switch assembly. The stop filters are tuned to the "opposite" frequency range, much like a set of duplexers in a repeater system.
    If you substitute a power combiner and pass/stop filters, you could eliminate the switch altogether and use both radios at the same time...assuming different operating ranges for each.
    I've heard of people doing it without any problems but I've also heard otherwise so I guess it's a roll of the dice. You pay your money and you take your chances, I just think that the cost of crapping out is too high.
    And heya right back at you Rob. How's your own fine self?
    And heya, Carlo!
    Be seeing you,camera boyo!
