Results 1 to 10 of 18
Thread: Unknown Signal Type Seen with Cocoa Modem
    Newbie
    Sep 2016
    Ailey, GA
    Hi, I'm N1RPN and I'm learning to run RTTY using Cocoa Modem 2.0 running on a Mac G4, and Icom 720a and a 40 meter dipole.
    But I see in the Wideband RTTY waterfall display a signal that appears as 3 signals side by side and interesting Lissajous patterns in the tuning display. Any idea what this is?
    73 N1RPN
    Oct 2011
    Hillsborough, NC
    Jim
    Post a screen shot--command-shift-3
    ^^^That
    Kinda hard to tell from a verbal descript.
    Newbie
    Sep 2016
    Ailey, GA
    Does this help?
    Newbie
    Sep 2016
    Ailey, GA
    And from the same transmission but later.
    AA1OH doesn't recognize the sound and he's good.
    Gibberish being caused by your connections between the radio and computer. Try ferrite beads and or better shielded cables to keep out interference.
    Newbie
    Sep 2016
    Ailey, GA
    Nice watch you got there KG4CGC, but FWIW this is the system that I use to make RTTY contacts, read PSK and receive HF Weather Fax transmissions. This weekend past, after I screwed up my courage to put my hat on a stick, poke it around the corner and try a live CW contact, I used this system to tell me that buzzing I hear everywhere was 50 WPM CW evenly spaced about 1KHz apart. 73 N1RPN.
    The Lissajous Crown of Thorns
    Join us in general chat for a drink.
    OK, if that's not it then that's all I got. I had a similar issues in psk and sorted it better interface cables.
