Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Something(s) followed me home - old Tempo (Uniden) 2020 station
  1. #11
    Tribal Warrior AA1OH's Avatar
    Dec 2015
    Lyons,ga
    Nice looking rig-I remember going into Henry Radio and wishing for the Tempo One rig, walked out with a National NC-300 as my first "Ham" receiver.
    I thought religions were prophet based organizations.
    What do you mean I am out of money? I still have checks!
    Remember, amateurs built the Ark, professionals built the Titanic
  2. #12
    Quote Originally Posted by AA1OH View Post
    I still have the rusted out chassis on an NC-33 I got when I was 10. It was working until I was 33. Then it got put away and eventually ended up in an outdoor building. By that time I had the fever for the newest offerings from Japan.
  3. #13
    Dec 2015
    Lyons,ga
    I had the big brother to the NC-33, A NC-57! 9 tubes!
  4. #14
    An update on the original post:
    The 2020, remote VFO and speaker are in service now, having replaced my FL-101/YO-101/SP-101 in the "vintage" lineup. A basic rundown of what was done -
    * Replaced the RF Attenuator/Cal pot-switch assembly
    * Reworked the input header to the VCO Board
    * Fixed a cold solder joint on the VCO Board and aligned the VCO
    * Replaced a defective RF transformer on the RX Board - will eventually rewind the stock unit as it's shorted. Replaced a fixed ceramic capacitor to allow the tank circuit to resonate correctly on 80M
    * Replaced the stock rear panel SMK 4-pin accessory connector with a DIN-5 type, and wired up an accessory cable to match
    * Fixed a loose coupler in the PA bandswitch area
    * Cleaned the antenna changeover relay and fixed a broken lead on its socket
    * Diagnosed a TX Board condition wherein the 80M drive level couldn't be reduced. This needs further investigation but the rig is usable on all bands now
    * Aligned LO, TX, RX, Regulator and Generator Boards
    * Physically and electrically rebuilt the external VFO. Additional work needed; more on this later
    * Combined parts from a non-amplified Astatic 878 and Drake 7077 mics to get a fully functional high-impedance unit then wired it to the rig
    * Verified function of the Operation board, including rework of its connecting header and rotary switch leads
    * Applied DeOxIt to every potentiometer and rotary switch in the rig
    The local 10M crowd (audiophoolsphiles...errr, ESSBers, all of them) will give me a ration of sh!t if I show up on frequency with something that doesn't sound quite right. (I've done a bit of SSB generator work for the gang, so I better be eating my own dog food...) To a man and woman, they all like the way this rig sounds - a lot more than the FL-101 which it replaced, and which is going on the bench this winter for R&R work.
    I still have to figure out why the Remote VFO quit "fully operating", and I think it's due to an intermittent switching relay - an Omron MH6P 12VDC unit, long since obsolete. The non-ZD FT-101 series used these for the same basic functions (i.e., meter switching, T/R control line switching) and after studying the schematic I think it's where the trouble lies.
    (Of course, it WAS working - somewhat - before I applied a bit of DeOxIt to the contacts. :( Fortunately, I have another inbound - and can always change the setup over to use a Magnecraft equivalent if that fails.)
    At the moment I have my FR-101S slaved to the 2020, albeit in "separates" mode. No way to have the radios run in full transceive operation (like the 101 twins, or the TS-820S/R-820 pair sitting next to them) but it isn't that big of a deal to re-spot the VFOs if they drift. To the Yaesu's credit, once warmed up it stays put on frequency for days on end.
  5. #15
    Nice rig. I need to get back on HF. The rig is sitting upstairs and I still have a 30' vertical...
  6. #16
    Quote Originally Posted by N2CHX View Post
    Nice rig.
    It's a geezer radio, as one of our infrequent members calls rigs of the period. But it works for its intended (rag chewing) purpose - no way this thing's slicing and dicing on contest weekend.
    And I still have crystals for you for that 30M project of several years back.
  7. #17
    I must have forgotten all I ever knew about R/C @ audio frequencies because altering the input network , C526-C529 / R547 , R549 , R550 has had demoralizing effects at worst and no effect at best . I have changed R551 to 15K and C532 to a 10uf@25V to get a bit more gain but it seems at the expense of low end frequency response .
    Better late than never ...
