Results 1 to 10 of 14
Thread: Signalink vs Rigblaster vs...?
    Who's got some run-time on all of these interfaces and can give me the pros and cons of each? Additionally: Are any of you using a Rigblaster for rig control in addition to digi-modes operation - and if so, which programs are you using?
    I currently have one Signalink USB in the shack. I'll need at least one more of the things for my two-position PSK/JT65/RTTY operating layout. All of the rigs in the lineup are Ten-Tec and all require a level converter to use their secondary serial interface - the main serial ports are tied up with connections for amplifier and automatic tuner control. I see the high-end Rigblaster incorporates a CI-V (Icom style) converter and one per controlled "spot" will make this project work just dandy. That is, if it plays nice with other gadgets...
    Basic diff is Rigblaster sets up separate USB control for functions, Signalink is one.
    For me (I have two RigBlaster PnP units), external PTT for keying was the winner.
    Better for CW, AND... Don't want VOX keying, I like my winders noises to stay off the air.
    It's a little more nonsense to set up the RigBlasters, but I don't think that would bother you. ;)
    I have been using a SignaLink for PSK-31 and JT-65 for years with no issues, although I've heard it said that the VOX keying can be problematic in a few of the more esoteric digital modes. If Dave is having troubles with his Winders sounds keying his rig, it's because he hasn't set up his software correctly.
    No, it's setup just fine, and I avoid it easily.
    I was being snarky. Le Sigh.
    Peace, out.
    I bought the Cadillac of USB interfaces 7 years ago: http://www.navigator-interface.com/naviusa_004.htm
    Now sold by TimeWave: http://timewave.com/support/Navigator/
    I bought the Cadillac of USB interfaces 7 years ago [...] Now sold by TimeWave: http://timewave.com/support/Navigator/
    Man, that's gotta be the most effed-up code I've seen on a web page in some time.
    Quote Originally Posted by K6BSO View Post
    Man, that's gotta be the most effed-up code I've seen on a web page in sometime.
    Yeah, it's like 1998 all over again.
    Oh FFS! YES!
    Which rig control programs are you using with the Navigator, Jim?
    Primarily WSJT-X 1.5 (JT65/JT9) and MixW 2.18 (PSK, RTTY, and CW). Logger32, HRD, and fldigi have also worked in the past.
    If there's something specific you use, I can install it and test.
