Results 1 to 10 of 25
Thread: See if you can spot the problem with the following
    From one of the FB ham radio groups:
    Your not dedicated till you drive a ground rod home thru the south texas clay. Today i set up my hf20a wire antenna. This antenna needs 2 ground rods. The good news is that i get 1:1 swr from 160-10m no tuner.
    Anyone? Bueller?
    1:1 SWR from 160m through 10m without a tuner? That's not an antenna he's using, it's a dummy load.
    Mar 2009
    Queensgate
    Anyone? Bueller?
    You got me, maybe a picture of the installation might help. I looked the antenna up, looks like a OCF dipole terminated like a Beverage Antenna.
    Him claimed "1:1" match is problematic in wording and most likely improbable in real life; maybe he misread or misspoke in his description
    This was useful (not) in my understanding.
    Da Pope is wise.
    The only way you get those kind of results is with a lot of loss in the antenna system. Oh, you can get RF to radiate off of it, but the question is exactly how much of the total applied RF is getting radiated.
    Oct 2011
    Hillsborough, NC
    Whenever someone confuses RF ground with AC ground, Domo kills a kitten.
    Now we have to perform a sacrifice to W4RNL to right the wrongs.
    Jim
    I suggest a 200 watt incandescent bulb.
    My homebrew OCF works from 160 - 10 but will not be 1:1 everywhere....15 meters is baaaaaad ;)
    Though nowhere worse as 1:3 ( needs tuner) 160 - 80 - 40 - 20 -18 -12 -10 are moostly below 1:3 or even 1:1.2.
    First thought this is not an OCF antenna but an end fed antenna with a short piece counter poise and earth connection, clearly from the provided piccie you see only the short end grounded, the longer wire has the "Special purpose part" in it.
    Still a wire fed with 1:4 or 1:9 un un won't give you 1:1 on all bands.
    Possibly with a ruddy large non inductive 50 Ohm resistor in it ;)
    From their advertisement:
    Package Contents:1× HF20A Balun(The white Box)1× Special-purpose part (The golden metal Box) Must be that 50 Ohm ruddy big resistor then ;)
    http://www.aliexpress.com/item/HF20A...050744819.html
    More piccies of the gold colored heatsinked "Special purpose part" LOL
    Here they state SWR < 1 :2
    Radiating wire 20 meters, short side 1.5 and after the "special purpose part" to ground also 1.5 meters.
    So in effect a radiating dummy load.
    Most power will be lost in the balun and resistor, though on some frequencies it might actually radiate a bit better as a leaky dummyload.
    You know how things work, if anyone didn't had a decent antenna up and tries this as first one it is a very good antenna.....
    Till he finds out what a real antenna does.
    Same reason I'm not a fan of the folded dipole. Resistive loads are futile.
    Da Pope is wise.
    I made a PSK-31 contact with a friend while he was testing his rig into a dummy load so, yeah, I agree—you can get some RF to radiate off of pretty much anything. That doesn't make it a good antenna, however.
    Cor, I think you're right. That “Special Purpose Part” looks suspiciously like a high-wattage resistor, doesn't it? Check out this page!
    Oct 2011
    Hillsborough, NC
    They make fairly good driven elements, though.
    Jim
