[john@localhost openbve]$ mono OpenBve.exe
Stacktrace:
at (wrapper managed-to-native) System.Drawing.GDIPlus.GdipLoadImageFromFile (string,intptr&) <0xffffffff>
at System.Drawing.Image.FromFile (string,bool) <0x0005b>
at System.Drawing.Image.FromFile (string) <0x0000f>
at OpenBve.formMain.LoadImage (string,string) <0x00037>
at OpenBve.formMain.formMain_Load (object,System.EventArgs) <0x00c9f>
at System.Windows.Forms.Form.OnLoad (System.EventArgs) <0x00075>
at System.Windows.Forms.Form.OnLoadInternal (System.EventArgs) <0x0007f>
at System.Windows.Forms.Form.OnCreateControl () <0x00053>
at System.Windows.Forms.Control.CreateControl () <0x00127>
at System.Windows.Forms.Control.WmShowWindow (System.Windows.Forms.Message&) <0x00193>
at System.Windows.Forms.Control.WndProc (System.Windows.Forms.Message&) <0x002c7>
at System.Windows.Forms.ScrollableControl.WndProc (System.Windows.Forms.Message&) <0x00013>
at System.Windows.Forms.ContainerControl.WndProc (System.Windows.Forms.Message&) <0x0005b>
at System.Windows.Forms.Form.WndProc (System.Windows.Forms.Message&) <0x0024f>
at System.Windows.Forms.Control/ControlWindowTarget.OnMessage (System.Windows.Forms.Message&) <0x00024>
at System.Windows.Forms.Control/ControlNativeWindow.WndProc (System.Windows.Forms.Message&) <0x00036>
at System.Windows.Forms.NativeWindow.WndProc (intptr,System.Windows.Forms.Msg,intptr,intptr) <0x002f0>
at System.Windows.Forms.XplatUIX11.SendMessage (intptr,System.Windows.Forms.Msg,intptr,intptr) <0x00313>
at System.Windows.Forms.XplatUIX11.MapWindow (System.Windows.Forms.Hwnd,System.Windows.Forms.Wi ndowType) <0x001fb>
at System.Windows.Forms.XplatUIX11.CreateWindow (System.Windows.Forms.CreateParams) <0x00d53>
at System.Windows.Forms.XplatUI.CreateWindow (System.Windows.Forms.CreateParams) <0x00024>
at System.Windows.Forms.NativeWindow.CreateHandle (System.Windows.Forms.CreateParams) <0x0003f>
at System.Windows.Forms.Control.CreateHandle () <0x00069>
at System.Windows.Forms.Form.CreateHandle () <0x0001b>
at System.Windows.Forms.Control.CreateControl () <0x00087>
at System.Windows.Forms.Control.SetVisibleCore (bool) <0x0009f>
at System.Windows.Forms.Form.SetVisibleCore (bool) <0x002ef>
at System.Windows.Forms.Control.set_Visible (bool) <0x00032>
at (wrapper remoting-invoke-with-check) System.Windows.Forms.Control.set_Visible (bool) <0xffffffff>
at System.Windows.Forms.Application.RunLoop (bool,System.Windows.Forms.ApplicationContext) <0x002b3>
at System.Windows.Forms.Form.ShowDialog (System.Windows.Forms.IWin32Window) <0x0079f>
at System.Windows.Forms.Form.ShowDialog () <0x0000f>
at (wrapper remoting-invoke-with-check) System.Windows.Forms.Form.ShowDialog () <0xffffffff>
at OpenBve.formMain.ShowMainDialog (OpenBve.formMain/MainDialogResult) <0x00133>
at OpenBve.Program.Main (string[]) <0x00a17>
at (wrapper runtime-invoke) <Module>.runtime_invoke_void_object (object,intptr,intptr,intptr) <0xffffffff>
Native stacktrace:
mono() [0x49e695]
mono() [0x4f09bb]
mono() [0x421fdd]
/lib64/libpthread.so.0(+0x100d0) [0x7f0369ce30d0]
/lib64/libgdiplus.so.0(+0x418b9) [0x7f03613dd8b9]
/lib64/libgdiplus.so.0(GdipLoadImageFromFile+0x1ad) [0x7f03613c0cdd]
[0x403bd20e]
Debug info from gdb:
Mono support loaded.
[New LWP 2687]
[New LWP 2686]
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib64/libthread_db.so.1".
0x00007f0369ce21cd in read () from /lib64/libpthread.so.0
Id Target Id Frame
3 Thread 0x7f036318b700 (LWP 2686) "mono" 0x00007f0369cdf590 in pthread_cond_wait@@GLIBC_2.3.2 () from /lib64/libpthread.so.0
2 Thread 0x7f03624c1700 (LWP 2687) "mono" 0x00007f0369ce1710 in sem_wait () from /lib64/libpthread.so.0
* 1 Thread 0x7f036a7f2740 (LWP 2685) "mono" 0x00007f0369ce21cd in read () from /lib64/libpthread.so.0
Thread 3 (Thread 0x7f036318b700 (LWP 2686)):
#0 0x00007f0369cdf590 in pthread_cond_wait@@GLIBC_2.3.2 () at /lib64/libpthread.so.0
#1 0x00000000005ed3a3 in GC_wait_marker ()
#2 0x00000000005f1939 in GC_help_marker ()
#3 0x00000000005ebb27 in GC_mark_thread ()
#4 0x00007f0369cda52a in start_thread () at /lib64/libpthread.so.0
#5 0x00007f03697ff79d in clone () at /lib64/libc.so.6
Thread 2 (Thread 0x7f03624c1700 (LWP 2687)):
#0 0x00007f0369ce1710 in sem_wait () at /lib64/libpthread.so.0
#1 0x00000000005d7086 in mono_sem_wait ()
#2 0x00000000005a30cb in finalizer_thread ()
#3 0x0000000000542fef in start_wrapper ()
#4 0x00000000005c41a6 in thread_start_routine ()
#5 0x00000000005ecfe6 in GC_start_routine ()
#6 0x00007f0369cda52a in start_thread () at /lib64/libpthread.so.0
#7 0x00007f03697ff79d in clone () at /lib64/libc.so.6
Thread 1 (Thread 0x7f036a7f2740 (LWP 2685)):
#0 0x00007f0369ce21cd in read () at /lib64/libpthread.so.0
#1 0x000000000049e82b in mono_handle_native_sigsegv ()
#2 0x00000000004f09bb in mono_arch_handle_altstack_exception ()
#3 0x0000000000421fdd in mono_sigsegv_signal_handler ()
#4 0x00007f0369ce30d0 in <signal handler called> () at /lib64/libpthread.so.0
#5 0x00007f03613dd8b9 in gdip_load_png_image_from_file_or_stream () at /lib64/libgdiplus.so.0
#6 0x00007f03613c0cdd in GdipLoadImageFromFile () at /lib64/libgdiplus.so.0
#7 0x00000000403bd20e in ()
#8 0x0000000000a73750 in ()
#9 0x00007f0353a7b0e0 in ()
#10 0x00007fffac264dd8 in ()
#11 0x0000000040e56418 in ()
#12 0x0000000000000017 in ()
#13 0x00007fffac264e80 in ()
#14 0x00007fffac264d90 in ()
#15 0x00007f0353a1c750 in ()
#16 0x00007f0353a1c750 in ()
#17 0x00007f0353a7b0e0 in ()
#18 0x00007f0353a7b0e0 in ()
#19 0x00000000403bd14c in ()
#20 0x00007f0353a1c750 in ()
#21 0x00007f0356da7000 in ()
#22 0x0000000000000000 in ()
Got a SIGSEGV while executing native code. This usually indicates
a fatal error in the mono runtime or one of the native libraries
used by your application.
Aborted (core dumped)
