Results 1 to 8 of 8
Thread: need antenna ideas
    need antenna ideas
    I have about 1 acre of land, A 40 foot pole, and some 60 ft trees. I am in need of an awesome multi band ,antenna for 80 through 10. All help appreciated. De Mike N5KB
    Wire curtain array?
    Oct 2011
    Hillsborough, NC
    85' freestanding tower, Tennadyne T10, M2 full-sized 2-element 40M beam and remote matching network to base-load it for 80 and everything else, plus a few miles of 12AWG radials...
    It's an idea :twisted::yum:
    Jim
    Is there a budget or wife involved?
    Keep it simple.
    Dipole-doublet cut for 80 meters, (its OK if it's a little longer) fed with balanced (ladder) line and a stout tuner for the power you are running. Put the feed point up as high as you can, vee or flat-top. A flatter dipole is usually better for longer distances on the higher frequencies, with a vee adding a vertical component to help longer distances on the lower bands. The flatter antenna will be more directional as well on the lower frequencies... broadside to the wire.
    A bonus for an antenna like this is it's real decent as an SWL antenna, just peak the receive noise with the tuner.
    Keep it simple.
    I Agree With This Completely
    Coconut King w6tmi's Avatar
    I wish I had this problem...
    I've accidentally swallowed some Scrabble tiles. My next crap could spell disaster.
    Quote Originally Posted by KG4NEL View Post
    FTW.
