I have a 40m hamstick dipole using a MFJ-347 as the center support. I'm wondering if it's feasible to hang a 20m inverted V using the hamstick mounts while the hamsticks are still mounted to it, making it a 20/40m dipole. I currently have the 40m hung as a vertical. I am wondering if keeping it as a vertical would affect the 20m inverted v in any way? How/will would they interact with each other in a negative way?
I have a bunch of 16g coated wire and I just need to solder a couple ring terminators to the ends and attach those to the screw in points on the hamsticks and raise it back up. OR I could just remove the hamstick dipoles and make it a monoband. Just need to get a few 3/8 x 24inch bolts.
Anyone have any advice on this?
Thanks
n2nkw
