Results 1 to 10 of 15
Thread: Duplexer...
    Master Navigator K9CCH's Avatar
    The Armpit Of, TX.
    Duplexer...
    What would a duplexer on a UHF/VHF be used for?
    For combining a uhf and a vhf radio to use a single feed line for a multiband antenna. They are also available to combine a HF output with VHF and UHF radios (Triplexer) to run everything down one coax for a multiband antenna much like you would do in a mobile situation where you don't have an antenna for each band.
    My 857 has the option to run HF +6 Meters out one jack, and the UHF/VHF out another jack, (it has a built in selectable duplexer) or you can select the option of running everything out one jack if you are using the ATAS 120 or equivalent. I have it set to run HF/6 to the ATAS 120, and VHF/UHF to a UHF/VHF antenna because at times I only use the VHF/UHF portion of the radio.
    What La Rata said.
    At Field Day last year, we used a triplexer along with some bandpass filters to allow three people to share a single tri-band Yagi—each on a different band, of course. It worked quite well, even if it did mean that all the work I put into building my 15m Moxon turned out to be for naught.
    Master Navigator
    ^^^But who got to "drive" the Yagi?
    Hmmm. AFAIK, the FT-857 does not have a duplexer built in.
    You have to install an external one to use a single feedline on an ATAS-120.
    Moot point. Duplexers are about $70, triplexers are about $10 more.
    You are correct, there is a menu setting that tells the radio the ATAS 120 is being used for 1.8-440 so it will tune the antenna properly, unless the VHF/UHF is going to a separate antenna. But you do have to use a diplexer to combine them onto one coax when using the ATAS for all bands.
    The Armpit Of, TX.
    I posted a WTB thread on the swamp for a VHF/UHF radio and someone locally replied. He has a Kenwood TM 733A with a Diamond duplexer for sale in original boxes. Wants $200 for the kit.
    I knew it had something to do with multiple feeds, I just didn't know exactly what it was for.
    That's not a bad deal. I like that radio, almost bought one.
    The Armpit Of, TX.
    I bought that FTM350AR for $450 or $500 and it was WAY too much radio for me, even though it was quite a pretty radio. So I figured I'd put something cheap and easy in the Jeep and start back at the basics and grow from there to see how much I use it.
    If I find myself using it a lot, and moving forward again with the hobby, then I'll look at upgrading later. I dont need all the bells and whistles right now.
    So this 733A is used, and I'm trying to decide between it, or a Yaesu FT2900R.
    Quote Originally Posted by K9CCH View Post
    That really is a very good price for that radio, and I believe it has cross band repeat on it which can be useful.
