Results 1 to 10 of 15
Thread: Duplexer...
    The Armpit Of, TX.
    Duplexer...
    What would a duplexer on a UHF/VHF be used for?
    For combining a uhf and a vhf radio to use a single feed line for a multiband antenna. They are also available to combine a HF output with VHF and UHF radios (Triplexer) to run everything down one coax for a multiband antenna much like you would do in a mobile situation where you don't have an antenna for each band.
    My 857 has the option to run HF +6 Meters out one jack, and the UHF/VHF out another jack, (it has a built in selectable duplexer) or you can select the option of running everything out one jack if you are using the ATAS 120 or equivalent. I have it set to run HF/6 to the ATAS 120, and VHF/UHF to a UHF/VHF antenna because at times I only use the VHF/UHF portion of the radio.
    What La Rata said.
    At Field Day last year, we used a triplexer along with some bandpass filters to allow three people to share a single tri-band Yagi—each on a different band, of course. It worked quite well, even if it did mean that all the work I put into building my 15m Moxon turned out to be for naught.
    Master Navigator
    ^^^But who got to "drive" the Yagi?
    Quote Originally Posted by wb5ydk View Post
    Nobody. One interesting thing about living in the extreme southwestern corner of the US is that 90% of potential Field Day contacts are more or less on the same beam heading.
    Hmmm. AFAIK, the FT-857 does not have a duplexer built in.
    You have to install an external one to use a single feedline on an ATAS-120.
    Moot point. Duplexers are about $70, triplexers are about $10 more.
    You are correct, there is a menu setting that tells the radio the ATAS 120 is being used for 1.8-440 so it will tune the antenna properly, unless the VHF/UHF is going to a separate antenna. But you do have to use a diplexer to combine them onto one coax when using the ATAS for all bands.
    The Armpit Of, TX.
    I posted a WTB thread on the swamp for a VHF/UHF radio and someone locally replied. He has a Kenwood TM 733A with a Diamond duplexer for sale in original boxes. Wants $200 for the kit.
    I knew it had something to do with multiple feeds, I just didn't know exactly what it was for.
    Quote Originally Posted by K9CCH View Post
    That really is a very good price for that radio, and I believe it has cross band repeat on it which can be useful.
    That's not a bad deal. I like that radio, almost bought one.
