Results 1 to 6 of 6
Thread: Need help with a stealth antenna
    Kilroy08 W3MPS's Avatar
    Too close to Salem Island
    Ladies, gentlemen. After a long absence, I've gotten the itch to put my station back on the air.
    Here's the problem, I'm stuck living in a condo. Also, it's on the ground floor.
    I *cough* have access to the roof and there's a drain pipe rather conveniently located next to my unit.
    And the building is three stories, at least I'll get some elevation out of it.
    I'm considering a long wire tacked along the parapet on the roof and running a feeder concealed in the drain pipe.
    Or make the drain pipe the vertical leg of an inverted L.
    For right now, I'm limited to 10 meters. Ideally I would like to design things with an eye towards the other HF bands
    as I am working on studying to upgrade my license.
    Any guidance is greatly welcome in my latest pursuit of black ops shenanigans.
    http://pa0fri.home.xs4all.nl/Ant/Ant...al.htm#PLATDAK
    Have a lookie here, in Dutch but with piccies to give you an idea ;)
    Do scroll down on that page...
    A wire up the drainpipe would be quite good but probably suffer from EMC from all the gadgets running in the condo. I suggest two parallel 75ohm coaxes to the roof giving you a waterproof 150 ohm feeder.
    Quote Originally Posted by HUGH View Post
    Interesting, I had not considered that.
    I turned on the radio with a cheapie "10 meter" mag mount hooked up to it. There's a fair amount of RF noise in the place. We shall see how it goes.
    Do you have access to the roof? A hamstick or equivalent attached to a vent pipe would be virtually invisible.
    Are you allowed a flagpole?
    How about a front porch or patio? A potted climbing plant, with a trellis that just HAPPENS to be about 4 feet high, can be a great disguise for one or more hamstick type antennas.
    Tiki Bearer
    Jun 2013
    Is your car parked nearby? Mount an antenna on the car and run a length of coax in through the window when operating...
