Get thee onto eBay or any of the usual ham radio site classified ad sections.
Look for a used HR2510 or HR2600 - preferably the latter - and a Wilson 1000 or K40 antenna.
Should be able to do this for $100-150 if you're careful.
Place in and on your vehicle then have a blast. I used such a setup in the early 90s and easily worked DXCC just driving to and from work.
The spectrum from 26-30MHz has been very active lately with regards to F-layer propagation.
this is why I tell newbs don't run out and by a HT for 1st radio. get a real rig with a real antenna and good feedline.
I am really not trying to be a dick about it but I have seen this time and time again. new guy gets ticket, runs out grabs a HT. ends up only able to hit 2 or 3 machines and all of them are dead. then gets discouraged cause nobody is around and ends up HT in a box in the closet never to be used again.
Hi Patraic, welcome to the intriguing world of hamdom, and the even more intriguing Island, you'll soon discover why we're the whacky and wonderful Misfits.
Two things I should mention about that ground plane since I used to make and mount them the same way and I didn't bother to watch the video. I used 12ga bare copper wire the first time, big mistake, it bends in heavy wind. Then I used 1/16in diameter brazing rod, it worked like a charm. Be sure you waterproof it so water doesn't creep into the coax and ruin it. First, when it's completed and before you put the mast up, wrap the connectors and a few inches down the coax with cheap vinyl electrician's tape, the expensive stuff like 3M doesn't stretch or stick well. Then put a glob of silicone bathtub caulk on the insulator.
You may consider a high gain antenna because with only 5W you'll need all the effective radiated power (ERP) you can get and height is might. Then somewhere down the road, it's a bit expensive but you get what you pay for, an all band all mode transceiver and 12VDC regulated supply adequate for power demand plus head room, I suggest 200% for cool operation. Some time ago I bought an Icom IC706Mk2G and love it, 100W 160-6M, 50W 2M and 25W 70cM. Just remember that FM is the only vertically polarized mode for the sake of mobiles, some 6M mobiles use horizontal halos for SSB. FM is the most power hungry mode too, range is considerably less than others which is why repeaters came about to extend mobile range. Now they've become hangouts but I digress.
Last but not least, my first supply was a car battery and a 4A regulated supply I had kicking around, left on 24/7/365 to trickle charge the battery. Don't worry about explosive hydrogen gas or acid spatter, that only happens at high charge rates. Don't worry about overcharging the battery either, current tapers off as the battery charges and at full charge current is very low, only determined by the battery's internal resistance, Ohm's Law.
Don't lose interest like many in your situation do, get involved with a local club and you'll find a bunch of guys to elmer (teach) you and help you along. One hint based on my experience, the best clubs don't have repeaters, those that do often have an inner circle of repeater elite snobs, but you can ignore them on and off the repeater(s). Not all clubs are ARRL sponsored, but they're a little harder to find, so I wish you the very best of luck. Like a couple of old sayings go, keep on pushin' and keep movin' on up, and sooner or later you'll be up there with the big boys.
Thanks for all the advice. Wind isnt a big issue out here in the wet northwest but rain is so il be sure to waterproof. good thing is that my 4 sq ft of backyard is mostly covered so i don't have to worry about wires getting wet to much. I was thinking about holding off on a HF rig until i get my General because i will have a lot more privileges as far as the HF spectrum so in effect more bang for the buck. As i have mentioned i have attempted to get with the local club but haven't had to much success because of my wonderful duty schedule.
Welcome.
If all you have is the 2M/440 rig, go for improving the antenna until you can improve the station. The twinlead J-pole suggested is very inexpensive, and a good performer. Until you can upgrade the station, I'd check the stuff that RGR posted. That should be a great resource for you.
And don't worry about being newish. We on the Island don't care what religion anyone is.
