Results 1 to 10 of 13
Thread: PROBLEM WITH CALLS-SIGN LOOKUP ON FLDIGI
    I have encountered a problem with FLDIGI after running it for nearly 2 years. It is running on a iMac Computer and has performed flawlessly up to two days ago. I noticed that when I put the cursor over a call-sign and right click to do a call lookup... I no longer get the prompt that asks for a call-sign lookup. If I select the call-sign and insert it into the Call-sign cell then use the Globe lookup it works fine. I looked over all the setup to ensure that nothing was changed that might cause this problem but, everything looked fine. We have gone over the manual, posted at another site but have not found the answer to this problem. I am hoping that someone else has encountered this same problem and can provide me with some tips or a solution.
    73's Don
    W6PJJ
    Conch Master W2NAP's Avatar
    Mar 2008
    W2NAP
    what version do you have. I got 3.21.74 Linux and my call lookup works fine (using HamQTH)
    Witch Doctor
    Apr 2010
    Did you check out all the suggestions made at the other site?
    In particular, is the Callsign DB tab in the configuration menu set up correctly for QRZ lookups?
    If you're relying on QRZ lookup via internet (i.e. without a subscription) you should have the box checked that says "QRZ online via default internet browser". If you're using HamCall or Callbook, check the appropriate box. If you have a paid subscription to the database enter your user/password information.
    Remember to Save the changes before closing the configuration popup.
    On Mac OS X, Fldigi puts an invisible directory (folder) labeled .fldigi at the root level of your home directory. You can force the Finder to show it by using the Show Config item from the File menu. Try moving the fldigi.prefs file out of the folder and then restarting Fldigi. That might take care of the problem.
    ON EDIT: You will have to re-enter all your personal data—call sign, location etc. after you do this.
    Gents:
    Thanks for the responses. We have tried every suggestion in the book. What is very interesting here... is the fact that I have not made any changes to the configuration of FLDIGI on this Computer, this anomaly showed up out of the Blue. We will resolve this in time.
    Tnx Agn.
    73's Don W6PJJ
    Have you tried repairing permissions using Disk Utility?
    You might want to try astronomy.
    What language is FLDIGI written in? Does it use any form of Java?
    Sir:
    Do you believe that your comment is constructive... and relative to the topic?
    Don W6PJJ
    Quote Originally Posted by W6PJJ View Post
    Sir:
    Don W6PJJ
    That's just Eddie. He's not a bad guy. He's like the funny uncle in the corner or Hugo in the attic waiting for his fish heads!
