Results 1 to 10 of 19
Thread: fedora chromium problem
    Conch Master W2NAP's Avatar
    Mar 2008
    W2NAP
    idk why but the formatting when replying or starting new topic is fucked with Chromium browser under fedora 19. it will not space anything correctly just runs it all together
    I gave up on Google's browser long ago because of stuff like this. Firefox has numerous faults but it's still the best out there right now.
    Mar 2008
    W2NAP
    yeah id be using firefox now, but since fedora 18 all firefox will do when launched is pixilate the screen hard lockup.
    Huh ??? I'm using Fedora 19 (64 bit) and Firefox, Opera, and Chrome all work great. I mostly use Opera but Firefox also runs great on F19. Did you try running strace or running it under gdb to get some info as to why it balks.
    P.S. I presume you built chromium from source ? Did you have any issues during the build ?
    Mar 2008
    W2NAP
    Huh ??? I'm using Fedora 19 (64 bit) and Firefox, Opera, and Chrome all work great. I mostly use Opera but Firefox also runs great on F19. Did you try running strace or running it under gdb to get some info as to why it balks.P.S. I presume you built chromium from source ? Did you have any issues during the build ?
    got chromium from repo......as for the firefox problem no matter what I do to try and track the issue, as soon as FF is "clicked" to run screen pixalates, hard lockup nothing gets saved. i just gave up on FF and moved to other things.
    Mar 2008
    W2NAP
    test with opera
    test
    test
    opera spaces correctly, so its a chromium issue.
    It's strange though. Just curious is it running on a 64 but system or an older 32 bit system and is the Fedora version FC19-64 or FC19-32 ? I tried but I can't seem to recreate the problem here.
    Mar 2008
    W2NAP
    32Installed fedora on a neighbors laptop today, tried it on there and it works fine. so hard telling what it is.. I know it started with F18
    Chromium or Google Chrome? They are two separate products, and it would be helpful to know.
    Mar 2008
    W2NAP
    Chromium
