To tide yourself over, you can get a SWR meter from radioshack, make your adjustments at low power, and then once it's set, bring power up, slowly, taking the meter out of the loop when you're ready to transmit. They're about $30 last I checked.
You can easily build your own swr brige as well. I once needed a swr bridge quick and I picked up the one from RS. It worked quite well and supposedly handles power levels up to at least 1Kw. I just keep it inline between my transmitter and the Dow Key.
