Page 1 of 7 123 ... LastLast
Results 1 to 10 of 64
Thread: Homebrew geiger counter
    Tribal Elder mw0uzo's Avatar
    Dec 2010
    Cardiff, Wales
    Made a geiger counter from a kit. It's a MyGeiger kit from RH Electronics.
    Its very good!
    Inside
    Rear of pcb, with LiPo 1100mAh battery, charger and serial to USB converter 'mods' allowing charging from USB and datalogging via USB.
    In the case
    Almost completed unit
    Work to do: Add external detector socket and switch, make alpha pancake detector probe and beta/gamma detector probe.
    Cool!
    Dec 2010
    Cardiff, Wales
    Background level log
    How's that swing on a "Dosy meter"?
    Dec 2010
    Cardiff, Wales
    Mmmm pickled onions
    Oh, wait - thats not pickled onions. Thats Am-241, a strong alpha emitter
    Yum, 1.47uSv/hr with a load of plastic in the way, detecting the weak gamma and some of the weak beta that Am-241 gives off
    Dec 2010
    Cardiff, Wales
    CPM log with Am-241
    What tube are you using?
    Planning a trip to Japan?
    Dec 2010
    Cardiff, Wales
    Quote Originally Posted by KKM View Post
    SBM-20 tube from ebay.
    I'm waiting for an Si-15BG pancake detector to arrive to make the alpha probe, might get another SBM-20 to make an additional probe to complete the set, which will also double as an outside monitoring probe.
    Dec 2010
    Cardiff, Wales
    No, but that would be great to test it all!
    I'm going to set up a constant monitoring station with an SBM-20 outside, then feed the readings into a webpage, or submit them to one of the websites that provide a global map of readings. That won't be for a while yet. I have an old laptop that runs a QRSS grabber continuously, so will run this on it.
