Page 1 of 4 123 ... LastLast
Results 1 to 10 of 39
Thread: Baofeng UV-5R (Firmware 307) Review
    Well, got my radio, and the programming cable (I was too lazy to program channels on the actual keypad) for my first brand new, in the box radio. Yeah me! So, I can't compare boxing/shipping/etc with other rigs.
    These are the specific Amazon items I ordered:
    http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
    But, first impression on opening the box: It's not a slouch packaging job. The inserts held all the components in a plastic tray. I'm on Amazon Prime, so two day shipping was free, and I got it in two days, as expected.
    The radio came with a full charge, which I'm still working on draining (Manual says to drain it 3 times). So, three days of monitoring, and it's still full. The drop-in charger seems a little cheap. Nothing like the Maxon drop-in bases I've used in the past. But, to order a new one costs $8, so I suppose in this regard, you get what you pay for.
    The radio itself, however does not feel cheap. Battery latches, belt clip, antenna all look to be of superior construction. It's comparable to my HTX-420, without the die-cast case. Not sure if it would survive a fall, but neither would my smart phone, and I paid about $200 for that. I don't think any plastic case radio would do to well in most falling scenarios either.
    The antenna is a reverse female SMA connection (Male on the radio side, female on the antenna). Some people gripe about this, but I believe Yaesu hand helds are the same. It seems to me that it would allow the antenna to break before the radio connector (A good thing), which I like.
    Now, I've only been mostly monitoring, but I checked into a net, and had no issues. I also used a repeater to get an audio/signal quality report. Came back with decent audio, and signal quality.
    Programming on the keypad is painful, but no more so than programming my HTX-420, or my Yaesu FT-2500. Programming via CHIRP is easy-peasy. Had no issues with the cable I got.
    The radio comes with a belt clip, an earpiece microphone, a charging base, the stubby antenna, the radio, and a hand strap. Looking at the loop for the hand strap, I wouldn't trust it. People have reported the pin coming out of the belt clip, and I can see how that would happen. The pin doesn't have any heads on it. Just a straight pin. So, I'll keep an eye on it, and see if it works itself out of there (Likely will).
    The firmware I got on the radio is 307, which is the most recent (As of when I bought this) firmware. Firmware is non-updateable, so you get what you get. The radio does have VOX, so it should would well for digital modes (No PTT circuit needed). Radios can also do radio-to-radio cloning, with a single cable, which could come in handy during Emcomm stuff, field day, hamfests, etc etc.
    There have been some complaints about the manual being written in Engrish. This particular shipment had no such thing. While the manual is sparse, it's plainly readable.
    Overall, I'd say for $31 + $8 for a cable, this was a pretty sweet deal. Will it last as long as a Yaecomwood? Who knows? It's not submersible. It feels (In the hand) like quality construction.
    Any pictures?
    With your blessing & a couple of pictures of the unit (yours, not a generic one off the web), I can make a newsletter article out of it. (I'm ALWAYS trolling for content!)
    Any pictures?
    No problem. When I get home, I'll take it apart, get some pictures of it "As delivered", and then as assembled :)
    Some assembly required, batteries not included.
    You got it backwards. Some batteries required, not assembled.
    The Armpit Of, TX.
    I've got a Baofeng UV-5RA... actually I have two. The led flashlight on the first went out within 12 hours of opening it, so the vendor sent me a new one and told me to keep the old one.
    This is a good flowchart for on the fly programming without a cable or computer. http://www.miklor.com/uv5r/pdf/uv5r_ProgStd.pdf
    Get yourself the 3600 or 3800mah battery. My UV5RA lasts for about two weeks on a single charge.
    For the price, I enjoy mine. I think they are cheap, but it works... usually. I have nothing to compare it to, but I think its a quirky thing that you have to be able to tolerate to enjoy.
    This is what the UV-5RA looks like.
    Attachment 10219
    The Armpit Of, TX.
    Oh, and another thing. Firmware BFB307 is nothing more than BFB297 masquerading under another name. There have been no firmware changes since 297 except the name.
    ... or so I've been told by the baofeng officials.
    I've got no less than 6 HTs I don't use now. Can't imagine WTF I'd use another one for.
    Mullica Hill hamfest is in September. Some of these things are outta here.....
    The Armpit Of, TX.
    This will probably be the first... and last HT I ever buy.
