Today, I R one (inside joke from a 1970's Electronics R & D Lab).8)
A couple-of-3 days ago, a "Deluxe" fan used to push air around the room stopped working, it was late at night so, I didn't feel like making a trip outside to dispose of it. A few days passed and I decided to do something with it, on the way to the door, I passed a Phillips Screwdriver and the "Mister Fix-it" in me took over.
Next thing you know, the cage is over here and the fan blades are over there and, I'm sitting there with the motor in my hand. After having checked all connections and switches, I come to the conclusion that it's the damn "Pico" fuse that they use for protection. I cut the shrink fit tubing on the connections to the motor and there it is; needless to say, I don't have a replacement so, I cut it out and twist the wires together, apply electrical tape and re-assemble.
"Wha-Laa", almost.
After putting it back together and plugging it in, it takes off again a pushes air - BACKWARDS; the motor now spins in the opposite direction....:-?
I thought that maybe if I flipped the polarity of the AC plug going into the wall, the motor would go in the other direction.
