Nabbed this on ebay for £100, untested.
HP8922 GSM Test Set
Spectrum of 14MHz carrier modulated with 2kHz sin wave
Its a spectrum analyser 5Mhz-1Ghz, RF generator 10Mhz-1Ghz, AF generator, power meter and signal analyser. It can do AM modulation and FM demodulation.
Thankfully it all works perfectly and seems to be well calibrated.
Its one downside is that its minimum center frequency is 10Mhz, and the analysis span is also 10Mhz. So you can analyse down to 5Mhz, but you start to lose resolution as you have to increase the span to get there.
It has a 30W maximum RF power input.
I need to make something to get the 0-10Mhz that is missing. Does anyone have any experience with very low distortion mixers suitable for doing this? The additional problem is maintaining a 30W input, so there would have to be an attenuator and a mixer calibrated to put a signal into the low power auxiliary input.
Any thoughts?
