Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: What A Day
    Forum Addict KA9MOT's Avatar
    Apr 2010
    Macomb, IL
    Feedline question: what are you feeding it with? A long run of window/ladder line could be your saving grace as a tuning stub.
    RG-213 MIL into 4:1 homebrew balun. It is a support issue. Right now the thing looks like a wooden wedge a carpenter would place to level a window. A long and narrow triangle. My yard is 180 Feet long and 40 feet wide, but I rent and I have to use what I have and can not attach anything to the house.
    I got rid of my vertical because I couldn't keep the radials on the ground. Staple them down and the landlord would find a way to pull them up while mowing and he was always complaining about them. No towers allowed either.
    Steve KA9MOT
    Macomb, IL
    Apr 2010
    Macomb, IL
    you can always go this route http://degood.org/coaxtrap/ 80-10 trap dipole. 60ft overall.
    This is interesting.... I'll have give it some thought.
    Steve KA9MOT
    Macomb, IL
    Conch Master W2NAP's Avatar
    Mar 2008
    W2NAP
    Quote Originally Posted by KA9MOT View Post
    Thats what ill build up I think. course its not like full 1/2 wave dipoles or beams. but it get ya on air. (I had a ft-847 tossed to me) think ill build the 80-10 and build a 12-17-6 and put it inside the room here.
    also gonna have to build me a 144 and 432 horizontal loop for 2/430 cw/ssb
    Now, that's odd. I have several radials stapled down in my back yard, and they have never come up while mowing.
    I learned THAT one the hard way a long, long time ago, when I lost the 80 meter radial to my (then) roof-mounted HF6V; I hadn't had it properly stapled to the ground, the mower got it, and I had a fun hour removing copper wire from around the mower blade axis.
    I suspect that your landlord is afraid that that might happen, and is manually removing the radial(s).
    One thing that can be done... find a flat-bladed shovel, cut a small slit in the grass (just enough to get under the thatch & roots), slip the radial(s) in under the grass. Within a week or so, the slit is completely gone. Of course, it's easier for me to do this, since I'm not renting, just paying blood money a mortgage to the bank.
    Apr 2010
    Macomb, IL
    I'm certain that is what is going on. But, it is his property so I have to respect his "hints".
    I'm physically unable to lay out radials, so I must rely on helpers. I get crazy looks when I ask my helpers to staple the radials/coax to the ground. I'd probably get shot if I were to hand out shovels!
    Funny thing though.... my coax never gets pulled up.
    Steve KA9MOT
    Macomb, IL
